NDI
NDI Screen capture Lagging
I have 3 pc for Game Streaming i have one 3060 Gpu pc for Main production, Two 1660 Gpu Pc for Spectating and NDI Output, I will Collect Data from Two Spectating Pc to Main production PC through NDI Screen Capture or Screen Capture HX,
But My Problem is When i am Conneting Two Spectate pc in NDI Screen Capture its Getting Lagging in one Feed, If i Connect one pc on NDI Screen Capture and Another One in NDI Screen Capture HX i works Fine. I need Sollution for This,
How can i Use only one Capture? Either Screen capture or Screen Capture HX?
I have TPLINK TL-SG108E 1Gigabyte Swtich, My lan cable was Cat 6A, All Connected in Same network,
But still i have this Problm Kindly help me about this,
one more Doubt is there any ip setting for PC.
Joined: 4/18/2023(UTC) Posts: 2 Location: Belo Horizonte
I'm having the same delay problem between images from 7 Sony SRG-X400 cameras that generate NDI stream. When I use up to 3 cameras there is no delay, when I use 4 or more cameras I start to have a delay problem between them. Were you able to solve the problem?
Joined: 4/23/2017(UTC) Posts: 1,145 Location: Germany Thanks: 3 times Was thanked: 166 time(s) in 148 post(s)
Have you tried vMix Desktop Capture instead of the NDI tools already?
Joined: 12/24/2021(UTC) Posts: 349 Location: athens Thanks: 113 times Was thanked: 53 time(s) in 50 post(s)
Originally Posted by: hilton.moraes I'm having the same delay problem between images from 7 Sony SRG-X400 cameras that generate NDI stream. When I use up to 3 cameras there is no delay, when I use 4 or more cameras I start to have a delay problem between them. Were you able to solve the problem? Hello. When the problem starts to appear, have you checked your network if it goes to it`s limits? Or if in vmix RenderTime goes too high. These 2 things can make your ndi stream to lag
If a few NDI sources work and the more you add the more laggy it gets it's definitely a sign of a network overload. I made a clip to demonstrate how quickly even with a few source the network can be saturated. Hope that helps.
NDI
