I'd like to use the datasource routine in vMix for importing data to use for other actions, for instance to use it to set a PreviewInput.
So i made a title called RUNDOWNPANEL with to items: PVW_ITEM_NR and PVW_CONTENT_TEXT
Then i made this: dim PVW_ITEM as String = Input.Find("RUNDOWNPANEL").Text("PVW_ITEM_NR.Text") dim PVW_CONTENT as String = Input.Find("RUNDOWNPANEL").Text("PVW_CONTENT_TEXT.Text")
API.Function("PreviewInput", Input:=PVW_ITEM) This works fine, when the string of PVW_ITEM_NR = "1", the first input will be set in Preview
But when I try API.Function("PreviewInput", Input:=PVW_CONTENT) It does not work though the string of PVW_CONTENT_TEXT = "CAM 1"
Hope to get some advice here.
Thx in advance.
Joined: 12/27/2012(UTC) Posts: 5,089 Location: Belgium Thanks: 284 times Was thanked: 921 time(s) in 760 post(s)
Originally Posted by: Korne_B I'd like to use the datasource routine in vMix for importing data to use for other actions, for instance to use it to set a PreviewInput.
Thx in advance. Should work , check for correct name of the wanted input! in your script might help to check using console.writeline(PVW_CONTENT_TEXT ) to verify the data retrieved from the title is also correct Tip: avoid spaces !
I removed the spaces, so no "Cam 1" but Cam_1" but still not working. When using PVW_ITEM the console turns the right number but this is the return from the console with (PVW_CONTENT_TEXT): Starting Script "GS_PREV"
Stopping Script "GS_PREV" So just a blank line.
Any suggestions?
Originally Posted by: Korne_B I removed the spaces, so no "Cam 1" but Cam_1" but still not working. When using PVW_ITEM the console turns the right number but this is the return from the console with (PVW_CONTENT_TEXT): Starting Script "GS_PREV"
Any suggestions? Looks like your data is not going into the textblock of the title or the reference to reading it from the tilte is wrong somehow . I did test with putting a text in a title ( diff reference to the textblock name) be it manual or with datasourceand reading it according to your "code" and it worked Check the naming of the title textblocks Code:dim PVW_CONTENT as String = Input.Find("Title 0- The Classic Blue.gtzip").Text("Headline.Text")
console.writeline(PVW_CONTENT ) 'input named "demo" ; title & data source content "demo"
BTW one can display code much easier to read in post using choose language for syntac highlighting Code:Starting Script "GS_PREV"
So far so good with commandline prompt. But no change in Preview. Tomorrow I will create a new blank input and name it “demo”. See what happens then. I will let you know
