kon310
#1 Posted : Saturday, July 23, 2022 12:10:42 PM(UTC)
kon310
Hey Guys,
My Vmix PC is using two ethernet adapters. The one that is on the motherboard and a 2nd one that is a USB dongle. They are on different networks. What I would like to see happen is I bring in the SRT via my public static IP network, and then NDI it over to the 2nd network. Is this possible?
nikosman88
#2 Posted : Saturday, July 23, 2022 5:39:47 PM(UTC)
nikosman88
Greece
Was thanked: 53 time(s) in 50 post(s)
Yes you can do it.
kon310
#3 Posted : Saturday, July 23, 2022 6:08:58 PM(UTC)
kon310
I'd like to believe you, but I've tried a lot of different ways of implementing it, and I've come up short.
nikosman88
#4 Posted : Saturday, July 23, 2022 8:47:38 PM(UTC)
nikosman88
Greece
What ways have you tried? Srt source is another one input source in vmix. Then if you want to share this input over your local network you can do it via one of 4 outputs that vmix has.
kon310
#5 Posted : Sunday, July 24, 2022 7:00:40 AM(UTC)
kon310
The NDI doesn't broadcast out of both networks for some reason.
My PC is on two different networks at the same time. I'm trying to capture the NDI signal on a different PC which is part of one of those networks and it's not coming through.
nikosman88
#6 Posted : Sunday, July 24, 2022 8:44:00 PM(UTC)
nikosman88
Greece
Maybe i dont understand exactly what you want to do. Personally i do this. I have one pc with vmix which also have 2 network cards. One in motherboard that is connected to my local network with a network switch and a 2nd one usb ethernet card that is connected in another router that gives me internet. With this 2nd card i accept an srt input in vmix and then this input i can share to my local network with the other ethernet card from vmix output ndi
kon310
#7 Posted : Monday, July 25, 2022 12:50:02 PM(UTC)
kon310
And does it just work automatically? You don't have to make any specific configurations about where to tell the streams to come in or go out? You just plugged in your network cables and it all worked without any issues?
nikosman88
#8 Posted : Monday, July 25, 2022 8:13:29 PM(UTC)
nikosman88
Greece
Yes and no. For incoming srt stream im using zerotier vpn because my internet provider doesnt allow me to open ports in router. But yes after this and once i receive srt in vmix everything else work ok without any extra settings. If you allready accept srt stream in vmix, then you should be able to send it with ndi everywhere in your local network without any extra settings
kon310
#9 Posted : Tuesday, July 26, 2022 12:53:02 PM(UTC)
kon310
okay sounds good. thanks for clearing that up for me.
