Feature Requests
Shortkeys separately for each individual project?
Joined: 2/18/2019(UTC) Posts: 54 Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Hello together.
Since I am using a StreamDeck XL there was rising a problem with shortcuts.
What I do: I have created several projects that are very similar. So that I don't have to change various little things every time I use one of the projects, although it's easy to forget something. :) On the stream deck I have created several pages to control Vmix overlays, slow motion etc. But not all of them work with every project and in some projects the inputs are different.
It would be a little dream if you could save shortcuts for each project separately. You load the project and the set of shortcuts and activators(!!) will be loaded. Perhaps via a separate shortcut definition file that is stored in the project file if the project file is otherwise too large. You could also import such a shortcut file into another project, edit it further and save it again.
At the moment there is only one configuration of shortcuts and activators for ALL projects and StreamDeck pages, and that is unnecessary, confusing and sometimes I even get conflicts.
Can VMIX make this little dream come true for me?
Joined: 12/27/2012(UTC) Posts: 5,095 Location: Belgium Thanks: 284 times Was thanked: 922 time(s) in 761 post(s)
Originally Posted by: burie It would be a little dream if you could save shortcuts for each project separately.
Check the shortcuts as local (this preset only) ?
Originally Posted by: doggy Originally Posted by: burie It would be a little dream if you could save shortcuts for each project separately.
Check the shortcuts as local (this preset only) ? oops... I hadn't understood the function of this checkbox until now. Thanks.
Joined: 4/27/2018(UTC) Posts: 28 Location: Brazil Thanks: 334 times Was thanked: 16 time(s) in 6 post(s)
Originally Posted by: eduardocfs +1 read above, allready possible
Feature Requests
