64 Pages«<5859606162>»
sophetyo
#1181 Posted : Sunday, February 13, 2022 1:18:12 AM(UTC)
sophetyo
Hi Team
I have problem with UTC
It doesn't want to sync with my Vmix.
With local IP and Netwaork IP
Yellow statut and link.
An idea ?
Thx
dmwkr
#1182 Posted : Sunday, February 13, 2022 4:42:54 AM(UTC)
dmwkr
Was thanked: 119 time(s) in 108 post(s)
Snooker Loopy
#1183 Posted : Sunday, February 20, 2022 7:47:25 AM(UTC)
Snooker Loopy
@elgarf, @DWAM
I'm getting pretty desperate for some advice regarding UTC crashing - if anybody could help I'd be most grateful.
UTC version 07.02.21 (and it also happened with version 17.06.19 and found it difficult to shut it down without force closing). VMix version 24. OS is Windows 7 SP1 (fully updated with the exception of MS Edge browser).
Sometimes it can go 30 minutes and other times it just crashes out after 2 or 3 minutes.
Have checked .Net framework 4.8 and run repair tool. Also checked and reinstalled Visual C++ Redistributable 2015
Anybody any other suggestions / fixes that I can try before resorting to my 5 year old Excel scoreboard. My additional problem is that I have four separate streams running on four separate laptops and each one is experiencing the same problem :-(
I have UTC log and Event log zipped up and have attached if anyone cares to give them a look over.
UTCCrash.zip (24kb) downloaded 15 time(s).
timbrian
#1184 Posted : Sunday, February 27, 2022 11:23:08 AM(UTC)
timbrian
Newly Created vMix UTC Tutorial Series
New Tutorial each Friday!
Alysson
#1185 Posted : Monday, March 14, 2022 10:47:08 AM(UTC)
Alysson
Brazil
Hello everyone,
I want to do an automation so that it can be used in my project, regardless of the vmix PC IP, that is, when I have my UTC project open and type the IP of the machine I want to control, I will have some buttons with API commands, in my project UTC, that I want to let the change (from this typed IP path) in an automated way.
To test the possibility of an automatic tool, I created an Input in vMix [Text Title].
I mapped this title to the widget inside UTC, with the IP path of a machine that is on the same network with vMix to be controlled.
The CUT button has a script, which takes the title text (with the IP) and completes the path of the button's script, in order to perform the cut action.
So, whenever I open my project to control a PC with vMix, I would only have to type the IP path of the PC to be controlled, and my API commands will all be changed automatically, I believe that this way I could have several buttons with different actions without worry about having to change the IP path for each button's API command individually.
If there is a way to get the IP directly from the command line of the UTC settings (127.0.0.1... or any other IP that will be typed in that line), it would be even better and faster, because it wouldn't need to have a title inside the vMix project, to get this data.
I thought of the following command line, but I don't understand programming, it's just an idea that I thought would work, so I'm in need of help, thanks in advance.
In UTC I created a button to test the reasoning of the script, in the properties of the button I created an API command, with the following command line, but I did not get positive results.
API
getvalue(split(_('Inputs[1].Elements[0].Text'), '|'), 0)/api?Function=Cut&Input=2
tntno
#1186 Posted : Thursday, March 17, 2022 10:22:32 AM(UTC)
tntno
Czech Republic
Hi, got problem. Just after I connected Google Sheet into UTC, everything works. but after 10sec it ccrashes everytime. When I remove Data widget with Google sheet database in UTC it stop crashing. Any help?
aircooled76@gmail.com
#1187 Posted : Sunday, March 20, 2022 6:35:57 PM(UTC)
Hi Folks,
Thanks for UTC it is awesome!
Hoping to create a way to switch the vMix call output of several calls, but get a "State Dependant" indicator to show the output being sent to each call.
If I check the "State Dependant" button the "Use in State Dependency" star is only there for the input, not the Source.
Is there a way to make the State Dependent Indicator trigger with a script? Any suggestions on how to achieve this?
Betinho
#1188 Posted : Wednesday, March 30, 2022 6:50:32 AM(UTC)
Betinho
2022-03-29.txt (19kb) downloaded 8 time(s).
Can´t Sync
UTC open but not Sync
Open in RED stat and Just stay in a Yellow before, dosen't stay in a Green
dmwkr
#1189 Posted : Wednesday, March 30, 2022 8:04:13 AM(UTC)
dmwkr
dror
#1190 Posted : Sunday, April 17, 2022 9:19:51 AM(UTC)
dror
Israel
Any Idea When UTC will Support the new color feature in the title input?
Chircanu
#1191 Posted : Monday, April 18, 2022 4:57:45 AM(UTC)
Chircanu
Hello everyone, I do not think that in the near future there will be any update to UTC, the "parent" UTC has not entered here for a very long time, nor do I think he will do it again. If anyone, of those who are good at it, would continue the work done by the elgarf would be SUPER
derrickrhems
#1192 Posted : Thursday, April 21, 2022 3:13:14 PM(UTC)
derrickrhems
Anyone know how to reorder widget inside of UTC? I have a file all designed but I need to push a button that I am using as a image to the back of my design
omo
#1193 Posted : Monday, April 25, 2022 5:33:20 PM(UTC)
omo
Hello, I think I've been looking for all the utc related articles for a month. However, I can't figure out how to use a static global variable.
Please let me know how to use it. I've been thinking a lot, but I haven't been able to find a solution.
I can't fully express my feelings with my poor English, but I'm desperate...
https://ibb.co/L6TWrJw
https://ibb.co/1bykZV0
PROMUSKA
#1194 Posted : Wednesday, May 11, 2022 3:43:20 AM(UTC)
PROMUSKA
Chile
no me conecta el syng a que se debe eso? siempre queda en rojo saludos y gracias
favoredtom
#1195 Posted : Monday, May 16, 2022 1:36:33 PM(UTC)
favoredtom
Looking for guidance on how to make my midi fader control an audio fader in UTC. I have seen to add this 'P * 100 / 127' in Execution link on midi device but then what do I add to the audio fader I want to control?
favoredtom
#1196 Posted : Monday, May 16, 2022 1:37:49 PM(UTC)
favoredtom
Originally Posted by: elgarf Go to Quoted Post
@leonardosfe219,
I made some changes in MIDI, so you can now access value from fader in script.
For example,
Code:
P * 100 / 127
Gives value from 0 to 100 for volume or something else.
Where do I put this in the Execute link for the midi controller? Then what do I put in the audio fader I want to control? Any help is super greatly appreciated!
#1197 Posted : Monday, June 6, 2022 2:23:13 PM(UTC)
Hi @elgarf,
Firstly thanks for a great tool.
I think we have found a bug... using BusXAudioON we are unable to choose the bus to turn on in the drop down list. (Function works correctly on BusXAudioOFF)
hpages
#1198 Posted : Thursday, June 16, 2022 5:39:17 AM(UTC)
hpages
I'm having an issue with UTC where it will not connect to the local host, 127.0.0.1, that os running vmix. It does connect to other PCs on my network that are running vmix without issue.
Does anyone have a solution for this? We used this set up over the past few days without issue and now it seems like something is blocking it from connecting to the local vmix.
The Sync status light also displays yellow in case that is helpful
I've attached the logs below.
I'm all ears if anyone has a possible solution
Thank you
2022-06-15.txt (1,086kb) downloaded 10 time(s).
dmwkr
#1199 Posted : Thursday, June 16, 2022 4:06:47 PM(UTC)
dmwkr
powercat
#1200 Posted : Thursday, July 7, 2022 3:10:40 AM(UTC)
powercat
Taiwan, Province Of China
Originally Posted by: chococrispis35 Go to Quoted Post
Elgarf
I will send you an email, it is an excel file, how to read from com2 a speed gun, this generates the speed for me, linked to the cg title, using the strokereader-2.6.4.0 program. the gun speed is a Stalker sport 2
hi I am currently helping students build a baseball broadcast project, and I am looking for how to transfer the data of Stalker Sport 2 Series Radar Guns back to excel or Vmix for subtitles, how can I do it?
Guest (12)
