NDI
GPU overload or insufficient router?
Good day to all
Please forgive my ignorance. My PC: Intel 7th gen 7800X (4.0Ghz, 15M Cache, 12x cores) CPU MSI X299 Raider LGA 2066 USB 3.1 DDR4 Motherboard MSI GTX 1050ti 4gb Gaming X GDDR5 Graphics card DDR4 16GB 2400mhz Quad Channel High performance RAM 2x 120GB Ultra-fast 240GB SSDa Raid 0 upto 900mb/s 1TB 7200 RPM 64MB Cache HDD Integrated 8 channel HD Audio Integrated Gigabit network Windows 10 64bit professional
My router: D-link DIR 825 My POE switch: 4 ports IEEE 802.3 10 Base-T IEEE 802.3u 100 BASE-TX IEEE 802.3ab 1000 BASE-T IEEE 802.z 1000 BASE-X IEEE 802.3x FLow control
Vmix version:21.0.0.61 x64
Capture Devices: 2x Blackmagic Decklink mini recorder USB/SDI. I only use the one at the moment, connected to a Panasonic MDH-3 Camera
NDI devices: Birddog eyes p100 Skaarhoj AirFly for Vmix Vmix desktop capture to overlay lyrics onto the Video
We are a church and we stream live to YouTube and Facebook Simultaneously. YouTube H264 1080p 4.5mbps sound 128kbps and Facebook H264 720p 3.5mbps 128kbps My problem started when I hooked up the NDI devices. The GPU started to give overload signals and after a while the video and sound would start to lag.
Do I need to upgrade the GPU or the router? Are there some settings that I can change? Please help, I have bought these NDI devices, but I can't use them without causing lag.
Gerrit
Joined: 3/7/2012(UTC) Posts: 2,605 Location: Canada Thanks: 33 times Was thanked: 501 time(s) in 470 post(s)
Joined: 7/1/2015(UTC) Posts: 1,150 Location: Houston TX Thanks: 319 times Was thanked: 263 time(s) in 233 post(s)
I've done more involved production with a GTX750 TI, so I doubt the GPU is the problem.
There may be other optimizations that are possible. Check your vMix logs to see if they can provide some direction.
NDI
