Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
Hi all, Previously I mentioned that I had used python to take data from timing systems and control vmix. The code was very messy and I started to tidy it up several times, but always got dragged away to something more important. This week I had direct message here asking about it, and that prodded me to spend a couple of evenings making a proper example. RS232_to_vmix_example.zip (2,539kb) downloaded 67 time(s). (You need to be logged it to download) I hope you find it useful, and fingers crossed it works for you :-) Here is the comment block from the top of the code: Code:#==================================================================
# A python example of receiving data over RS232 and using it to update Vmix using HTTP
# I hope this example is a good start for you create your own code.
# If you find any bugs or errors please feed them back so I can correct,
# I'm not a long time python programmer and am much more at home with low
# level C on a micro-controller, so many have occasionally done things in a
# non-pythonic way.
# This python example code is intended to be used with the accompanying vmix
# project which includes a title with items with the correct names
# The code is split in to 4 main parts:
# 1) The main() loop that calls the other parts.
# All the functions called by the main loop are fall through (non-blocking) so
# main() loops continuously, this is intentional so other things can be done here.
# There is a short sleep() in the main loop to reduce CPU load.
# 2) serialreader() that takes chars from the serial port, looks for start
# and end of message bytes and builds up the incoming message. When a full
# message is received it is passed back to the main loop.
# This function is fall through, in a larger project it would probably be better
# to use asyncio or a thread here, but the aim of this example is to keep it simple.
# This function could be modified to handle different protocols and do additional
# checks like verifying message checksums if present.
# 3) decodemessage() that tries to decode the received message and depending on the
# contents do things to update vmix. You could modify this for any protocol you
# are using, and what you want to with the data received.
# 4) A group of functions to update Vmix. send_vmix_command() actually sends the
# update to Vmix and the other functions like update_vmix_text() generate the
# specific commands to send. I normally add a new update_vmix_xxxx() function
# each time I use a new function in the list here:
# https://www.vmix.com/help26/ShortcutFunctionReference.html
# For this example lets invent a simple protocol to send commands over serial:
# All commands start with a '*' and end with a '!'.
# Note. Many protocols end in a LF or CR char but I have deliberately chosen
# not to here, to demonstrate 'Start' and 'End' of message markers.
# Parts/fields of the command are separated by comma.
# The first field is the command.
# Remaining fields are dependent on the command.
# Text values are in contained in "" to allow commas in text.
# Eg *command,field2,field3,"This is, field4"!
# This simple protocol has the obvious flaw that you can't include * or !
# in the fields, but it will do for this example code. Often the protocols
# I decode use 'unprintable' values as start & end of message markers eg: b'\x01
# (SOH) and b'\x04 (EOT). But here for ease of demonstration I wanted the
# protocol and commands to be possible to type in a terminal.
# And now lets invent some commands to use over this protocol:
# *NA,"England"! NA: Set the name of Team A to the value in field 2
# *NB,"Scotland"! NB: Set the name of Team B to the value in field 2
# *SA,1! SA: set the score of team A to the value in field 2
# *SB,2! SB: set the score of team B to the value in field 2
# *OE,1,1! OE: enable/disable the score overlay, field2: 0=disable,
# 1=enable overlay, field3: the Vmix overlay number
# *OE,0,1! example of turning off overlay 1
# HINT:, try the exact commands above on the supplied vmix project
# You will need to set the serial port and vmix ip address below.
# I have left commented out debug print() calls that you can re-enable
# if you desire to see what is going on at various points.
# This code has been tested on Windows, I'll try it on Linux soon and update
# these instructions.
# V1.0 MCL 31/3/2023
# - initial release
We use this technique for the overlays when we live stream swimming events like this: Regards, Mark Leman
1 user thanked markleman for this useful post.
