NDI
NDI Outputs stuttering
I cannot get a smooth NDI stream out of VMix. Trying to output 1080p59.94 via any of the outputs. Constant skipping and stuttering. Testing using a Unifi switch between my vmix workstation and a laptop running Studio Monitor and/or a BirdDog Flex 4k Out.
If I run NDI screen capture on the Vmix workstation and send the Fullscreen monitor output while still running Vmix, I get no stuttering from the Screen Capture stream. So it isn't the computer or the network or anything outside of Vmix.
Please advise.
Joined: 3/18/2021(UTC) Posts: 30 Location: Tokyo Thanks: 10 times Was thanked: 4 time(s) in 4 post(s)
Did you try : Disable QoS Set Flow Control enabled Disable Energy effecient ethernet and low-energy settingss Set fixed bandwidth(1Gbps or 10Gbps, maybe 2.5G or 5G) Set network "Private"
btw NDI Screen Capture send frame only when screen has motion/moving.(Sorry my English isnt good enough) So I never got Screen Capture smooth. vMix <-> vMix is very stable though.
I have BirdDog's FLEX4KBP, Studio, and Magewell HDMI Plus with NETGEAR's M4250 switch so let me know if you want to test something!
Joined: 4/27/2021(UTC) Posts: 14 Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Unfortunately there are 1000000 tiny optimizations to be done on a system from network nic to bios. But since you get it working pretty decently outside of vmix i suggest you manually update the NDI version in vmix. This has resolved lots of issues for me on some systems. https://www.vmix.com/kno...version-in-vmix-manually
Rank: Guest
Groups: Guests
i had a similar problem before, 100mbit network isn't enough to deal with NDI... make sure if your network is 1Gbit
NDI
