Instant Replay
New shortcut requests for Instant Replay
Hi all,
There are several shortcuts I'd like to have available in an update to the Instant Replay-system, so I've put a list here for others to add to. The replay functionality works mostly great, but I still need to move the mouse from time to time instead of just using X-Keys + a StreamDeck with Companion, that is the main thing all these relate to.
1. ReplayEditSelectedEventName Sets the keyboard focus to the angle description for the first active camera of the currently selected event, and activates the text box. As an operator, I currently have the jog wheel in one hand and the other on the streamdeck or the keyboard. Now I need to move my right hand off the jog wheel to the mouse, move the pointer to the correct line and event, right click on the area where the small dash is, then start typing. Bonus feature: clicking it again if you have ticked multiple camera angles for said event should activate the textbox for the next activated camera. There is a shortcut to set the text for the last event, but that does not allow dynamic values like this.
2. ReplaySelectPreviousEventList and -NextEventList. Dedicated buttons to select next and previous Event Lists, not separate shortcuts for ReplaySelectEvents1-20. At least give us "ReplaySelectEventsList" that takes a parameter so we could send in the current value +-1 to scroll between the lists. It's faster to click "NextEventList" thrice rather than finding the button for a specific list of 20 - and way faster than moving the mouse pointer again.
3. A modfifier button to allow us to select multiple events from a shortcut. I really like the PlaySelectedEvents-feature as that gives me a good indication of time remaining in the package while still keeping the "roll past out-point"-feature if the TD is slow to leave. I also typically navigate up and down in the EventList with dedicated shortcuts, and being able to hold down either a separate shortcut or the shift button while clicking ReplaySelectPreviousEvent / NextEvent and that working the same way as selecting multiple events with the mouse would be lovely.
4. ReplayCopySelectedEvents / -PasteSelectedEvents. Copy event functionality that doesn't require dedicated buttons for each event list you want to copy events to. I'd love a generic "Copy selected events"-shortcut, navigate to the event list I want with the shortcuts previously discussed, then simply click a PasteEvent-shortcut that will append it to said list. i could then move it up or down in the list if required. But this feature would enable me to copy an event to any of the event lists with just a few clicks, without needing a huge X-keys or streamdeck with a lot of dedicated buttons.
Thanks for the great software so far!
Joined: 12/27/2012(UTC) Posts: 5,404  Location: Belgium Thanks: 301 times Was thanked: 996 time(s) in 826 post(s)
Originally Posted by: AsgeirSH  There is a shortcut to set the text for the last event, but that does not allow dynamic values like this.
1) For any selected event : ReplaySetSelectedEventText And does accept Dynamic values Also ReplaySetSelectedEventTextCamera
The vMix API contains the currently selected events number One can retrieve this and add/subtract that with a value and do an APIcall (Script linked to a shortcut, like 1 for previous and one for next)
Originally Posted by: AsgeirSH  4. ReplayCopySelectedEvents / -PasteSelectedEvents. Copy event functionality that doesn't require dedicated buttons for each event list you want to copy events to. I'd love a generic "Copy selected events"-shortcut, navigate to the event list I want with the shortcuts previously discussed, then simply click a PasteEvent-shortcut that will append it to said list. i could then move it up or down in the list if required. But this feature would enable me to copy an event to any of the event lists with just a few clicks, without needing a huge X-keys or streamdeck with a lot of dedicated buttons.
While currently not possible to move/copy multiple selected events by shortcut function, similar to previous reply one could predefine a eventslist number and do an API call(Script) to copy/move a selected event to the predefined list number. as before shortcut up and down the Lists position and a shortcut to do the copy/move. No need to go back and forth between the lists each time. Could have a SD button that displays the currently selected eventslists to copy/move to
Also ReplaySetSelectedEventTextCamera What I mean by Dynamic Value is that I want the shortcut to enable the textbox and allow me to start typing - as far as I can read in the docs, you need to send the value in via the shortcut, no? If not, great! Will test later. Originally Posted by: doggy  2) ...
Note that I'm not talking about the events themselves - I'm talking about the different event lists. There is no current shortcut / API call to set active list from a number, is there? I'd need to do the logic to call one of the 20 different shortcuts to be able to go what is currently the next / previous? If I'm wrong here, I'd love to hear more details about this :) 4) The thing is that I don't want to have to predefine the eventslist numbers, but instead build a quick package on the fly when "something" happens. Thanks for the replies / suggestions though, will try it out.
I am too! Code:dim selevent as string = "ReplaySelectEvents"
dim xml as string = API.XML()
x.loadxml(xml)
dim theEvents AS integer = Convert.toInt32(x.SelectSingleNode("//input[@type='Replay']//replay/@events").value)
if theEvents < 20
theEvents +=1
API.Function(selevent & theEvents.tostring() )
end if
'if >1 do a -=1 to go other direction
 2 users thanked doggy for this useful post.
Joined: 7/6/2023(UTC) Posts: 3  Location: Nice Thanks: 2 times
Regarding Instant Replay, I'm considering buying a Streamdeck+ in addition to my Streamdeck XL. Could the knobs be used in a shortcut (as jog wheel) to control more efficiently the MarkIn and MarkOut of an event ? (I believe with ReplayMoveSelectedInPoint and ReplayMoveSelectedOutPoint) While I'm live, its difficult to edit that with the mouse...
Joined: 4/3/2022(UTC) Posts: 32  Thanks: 5 times Was thanked: 9 time(s) in 8 post(s)
Yes, you absolutely can use the knobs on a SD+ to move the in and out points of an event. You can either configure the knobs to 'jog' frames (and then have a separate button to update the in/out point of currently selected event to the current position), or you can configure the knobs to directly adjust the in/out point of the selected event. I recommend that you use BitFocus Companion if you are not already! And I have a free template to grab with a lot of these sorts of functions configured: https://furtive.gumroad....-template?layout=profileI don't have a StreamDeck+ page configured on that template, but you can see how the actions work on, say, the "In Point +0.5 Sec" button and instead adapt those actions for the rotary dials. As you have noted, it's very difficult to edit those in/out points with a mouse, so I'm glad you're thinking about how to work faster here!
Originally Posted by: nissart  Regarding Instant Replay, I'm considering buying a Streamdeck+ in addition to my Streamdeck XL. Could the knobs be used in a shortcut (as jog wheel) to control more efficiently the MarkIn and MarkOut of an event ? (I believe with ReplayMoveSelectedInPoint and ReplayMoveSelectedOutPoint) While I'm live, its difficult to edit that with the mouse... Don't know about with a streamdeck+ but is what we do with a shuttle pro and ReplayUpdateSelectedInPoint/OutPoint Combined with the ReplayjumpToSelectedInPoint/OutPoint for quick in/out finetuning Goes easy and really fast
Ah that's a good reminder for me to go update my Stream Deck buttons to utilize the newer ReplayJumpToSelectedInPoint and ReplayJumpToSelectedOutPoint functions... I still have my jury-rigged solution on those buttons haha
Instant Replay
