JohnDoe415
#1 Posted : Sunday, January 19, 2025 7:11:14 PM(UTC)
JohnDoe415
I run a sport livestream, with the following cameras:
Main camera
Left faceoff
Left goal
Right faceoff
Right goal
I use a Streamdeck and have several shortcuts set up to swap between inputs.
I cannot find a way to create and stack shortcuts to achieve the following:
Left team scores:
Press a Streamdeck button, that plays an instant replay in this order: Main Camera > Left faceoff > Left Goal
Right team scores:
Press a Streamdeck button, that plays an instant replay in this order: Main Camera > Right faceoff > Right Goal
The instant replay functionality defaults to ONLY pre-selecting Output 1, meaning I need to toggle the other camera angles to ON in the replay functionality.
I have shortcuts set up as follows, since the instant replay functionality always leaves Camera 1 (main camera) selected:
Left Camera shortcut: Streamdeck button 1 actions in this order:
Toggles replay camera left faceoff on ReplayToggleLastEventCameraX
Toggles replay camera left goal on ReplayToggleLastEventCameraX
ReplaySelectLastEvent
ReplayPlaySelectedEventToOutput
Right camera shortcut: Streamdeck button 2 actions in this order:
Toggles replay camera right faceoff on ReplayToggleLastEventCameraX
Toggles replay camera right goal on ReplayToggleLastEventCameraX
The problem arises, as soon as I switch between left and right shortcut buttons, the order in which the cameras are selected/unselected in the instant replay window falls out of sync, making my shortcuts that rely on them being UNSELECTED, to then select them, not work.
Any ideas?
dmwkr
#2 Posted : Sunday, January 19, 2025 7:27:18 PM(UTC)
dmwkr
Was thanked: 133 time(s) in 121 post(s)
Use the functions ReplayLastEventCameraOff and ReplayLastEventCameraOn instead of toggle, if I understood you correctly.
JohnDoe415
#3 Posted : Sunday, January 19, 2025 7:39:39 PM(UTC)
JohnDoe415
This doesn't seem to work, as if I trigger the newly created
ReplayLastEventCameraOff MainCamera
ReplayLastEventCameraOff LeftGoal
ReplayLastEventCameraOff LeftFaceoff
ReplayLastEventCameraOff RightGoal
ReplayLastEventCameraOff RightFaceoff
ReplayLastEventCameraOn MainCamera
ReplayLastEventCameraOn LeftGoal
ReplayLastEventCameraOn LeftFaceoff
and play the replay.
And then next trigger the newly created:
ReplayLastEventCameraOn RightGoal
ReplayLastEventCameraOn RightFaceoff
It works for the FIRST ever left and right replays, but as soon as I go to do a third and subsequent replay, it falls out of order, playing some of the right cameras during a left replay and vice-versa.
I don't mind what shortcuts I have to build, I just need a way of guaranteeing when I press the Streamdeck key, I only see that specific side's camera angles in the replay.
#4 Posted : Sunday, January 19, 2025 8:13:03 PM(UTC)
Was thanked: 975 time(s) in 808 post(s)
Make sure you always have a minimum of one angle on at any point ! (in fact its impossible to turn them off all , trying to turn of the last one that is on will be ignored)
Also shortcuts often need some time to excecute before another one will be performed correctly, try put these functions within a script and add delays between them (play with the delay times and when needed ) might help
