Joined: 8/22/2021(UTC) Posts: 26 Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Just for your information: I just found out that vMix is now installable over winget! I don't know when Studiocoast put it to the winget-repository, but from now on, you can install vMix by just entering winget install studiocoast.vmix in the Windows-commandline-interface or Powershell. Very usefull to automatically install your software without manually downloading it! Hint: Try https://winget.run or https://winstall.app/ to find out other programs you can install with winget!
Not very much response yet, so I assume most of you don't use WINGET.
Currently, there still seems to be a problem because vMix seems not to be complete conform to winget. So, winget can't read the installed version of vmix and always tries to reinstall it when upgrading.
Maybe the developers could fix it with the next version.
