NDI
Desktop Capture shows black screen
Joined: 11/25/2023(UTC) Posts: 2 Location: Hertfordshire
Hi there Wondering if anyone has come across this issue. A colleague of mine has a Dell desktop PC, very similar to mine. We were going through her performance settings and realised vMix was not utilising her Nvdia graphics card. We went through the relevant steps to change this. However once we did her desktop capture input type stopped working - it was working previous to the change when using the intel graphics card. I did the same change to my own machine not long prior to this and had no issues. Any thoughts on what this could be, and any fixes? I know using NDI Desktop Capture is a work around but wondering if there is a way to fix this. Thanks
Thanks: 62 times Was thanked: 119 time(s) in 108 post(s)
Make sure all monitors are connected to the GPU, not to the motherboard.
NDI
