Aki
#1 Posted : Monday, October 16, 2023 4:21:04 AM(UTC)
Aki
Hi.
In GT Title Designer under the Data tab, you can unhide a layer. This makes it possible to edit/modify the layer in vMix Title editor, also via Data Sources.
If it is a "graphics" layer you can now change the color, and also link the color to a datasource.
If it is a text layer you can change the textcolor via the GUI, but the datafield will only link to the text itself, not the color of the text.
Rectangle color
Would it be possible to also get the text color in vMix title editor, if you enabled this i GT Title Designer?
GT color text
Kindly Aki
Peter1000
#2 Posted : Monday, October 16, 2023 3:05:24 PM(UTC)
Peter1000
Switzerland
Was thanked: 73 time(s) in 54 post(s)
This has been asked here too, but I couldn't find the posts myself :-)
Answer, with example, here.
In my example, I turned off the "Hidden" checkbox" , so you can see what the shape is called and what color it is.
Ben777
#3 Posted : Tuesday, April 2, 2024 1:27:12 PM(UTC)
Ben777
i'm also hoping to change the colour of a text field dynamically using a DataSource -
Am i meant to be using as the workaround?
"Fetches the color of a shape from a GTtitle and then performs an action based on the color
#4 Posted : Wednesday, April 3, 2024 9:04:46 PM(UTC)
Was thanked: 921 time(s) in 760 post(s)
Originally Posted by: Ben777 Go to Quoted Post
Read the color of the shape from the API XML and do whatevere you like with it
Plenty of examples in Peter1000's link or scripting for dummies post
