Echtzeitstream-Berlin
#1 Posted : Friday, August 25, 2023 6:34:11 PM(UTC)
Germany
I have a new Alienware notebook that I want to use occasionally for vMix in addition to my desktop: Alienware M18 R1, i9-13980HX, RTX™ 4080.
I can enable Resizable BAR in the BIOS. However, no entry appears in the NVIDA system info. GPU-Z shows that it is active and in the driver resources it shows Large memory area. Is it active or not? Dell support says that ReBAR does not work on the Alienware M18 R1... which I would find a bit shameful.
How can I find out that vMix works with ReBAR?
I am grateful for all hints.
paco3346
#2 Posted : Friday, August 25, 2023 11:03:42 PM(UTC)
paco3346
Was thanked: 34 time(s) in 31 post(s)
Your GPU BIOS needs to support it as well. Unfortunately Dell hasn't seemed to care that much at enabling it on their cards. There have been some people who have modified their GPU's BIOS but I'm not sure how well that would work on a notebook.
(Even Dell's dedicated GPUs don't. I run my machine on an A6000 and don't get Resizable BAR.)
#3 Posted : Friday, August 25, 2023 11:26:46 PM(UTC)
Germany
but doesn't GPU-Z read all the information from the graphics card? Also the BIOS?
Similar Topics
Show Resizable Bar RAM usage % (Feature Requests)
by Rinsky 11/14/2023 9:08:06 PM(UTC)
Return new Legion 7i laptop? No Resizable BAR! (General Discussion)
by VideoE 11/7/2022 5:50:55 AM(UTC)
Resizable BAR on Lenovo Legion 7 2022???? (Hardware Compatibility)
by VideoE 10/30/2022 11:47:31 AM(UTC)
Resizable Bar on X299 Sage/10G (Hardware Compatibility)
by GlennRH 9/5/2022 9:24:15 PM(UTC)
Performance improvement with Resizable Bar (General Discussion)
by fluozh 8/13/2021 1:44:22 PM(UTC)
