NDI
Help! POE switch for live production- need to choose
Can you help or suggest a list of good 8 ports plus switches with Poe that I should buy to use with NDI cameras and multiple NDI laptops?
Definitely unmanaged as it will be used in clients locations. Also, i was told with a minimum speed capacity of 120gigabits.
Im good at many things but when it come to network, not my forte. Budget £500 or less.
Joined: 4/23/2017(UTC) Posts: 1,406  Location: Germany Thanks: 3 times Was thanked: 187 time(s) in 167 post(s)
Netgear AV line switches. HP or ZyXel should do as well. If you know RouterOS and won't mind using it, Mikrotik would be an option as well. But if you don't know it and networking isn't yours Mikrotik is nothing for ya.
NDI
