Systems
vMix 8 cameras replay on Intel 12900
Joined: 7/8/2016(UTC) Posts: 49 Location: Ukraine Thanks: 11 times Was thanked: 5 time(s) in 3 post(s)
Hi vMix community! I want to assemble PC for 8 cameras replays. I have DeckLink Quad 2 now with 8 inputs and Decklink minimonitor 1 output On vMix main page reference PC on intel 10980x processor, but it hard to find it. Is it possible to assemble on intel 12900 series, and how it will work? Does anyone have experience? I will be grateful for the information
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 57 Location: Canada
Was thanked: 17 time(s) in 16 post(s)
Hi Alex The main issue with the current generation i9-12900K CPUs is the lack of PCIe support, so you will likely only be able to connect one of your two capture cards. The other issue is the split nature of the cores and differing base clock speeds, the 8 Performance cores are fine @ 3.2GHz, but the 8 Efficient cores are a little slow @ 2.4GHz. As such, the i9-12900K will work with 6 to 8 Camera Instant Replay but is only slightly better than the Ruby Reference System. vMIx Greg
1 user thanked vmixgreg for this useful post.
Originally Posted by: vmixgreg Hi Alex The main issue with the current generation i9-12900K CPUs is the lack of PCIe support, so you will likely only be able to connect one of your two capture cards. The other issue is the split nature of the cores and differing base clock speeds, the 8 Performance cores are fine @ 3.2GHz, but the 8 Efficient cores are a little slow @ 2.4GHz. As such, the i9-12900K will work with 6 to 8 Camera Instant Replay but is only slightly better than the Ruby Reference System. vMIx Greg So, better to find 10980X?
Systems
