Bob Brazner
#1 Posted : Tuesday, December 21, 2021 2:45:24 PM(UTC)
Bob Brazner
Does anyone have a script that demonstrates how I can duck one input based on volume level of another input? I know I can do this with Waves C1 compressor, but I'm hoping there's a script way to do it.
I was hoping to be able to figure this out for myself by reviewing the object reference for the vMix API, but I can't even find that. Can anyone point that out to me?
Peter1000
#2 Posted : Tuesday, December 21, 2021 5:22:08 PM(UTC)
Peter1000
Switzerland
Was thanked: 79 time(s) in 60 post(s)
thanks 3 users thanked Peter1000 for this useful post.
doggy on 12/21/2021(UTC), jelutalica on 12/22/2021(UTC), raugert on 12/25/2021(UTC)
Bob Brazner
#3 Posted : Wednesday, December 22, 2021 5:34:17 AM(UTC)
Bob Brazner
I watched this video, but unfortunately it doesn't include any information about the script itself. So, the hunt continues.
#4 Posted : Wednesday, December 22, 2021 6:45:21 AM(UTC)
Was thanked: 961 time(s) in 795 post(s)
The full script is in the pinned comment. The comments within the script can be translated with google translate
Stealth77
#5 Posted : Friday, December 24, 2021 5:02:45 AM(UTC)
Stealth77
Russian Federation
Was thanked: 8 time(s) in 4 post(s)
'--- Many thanks to Kirill Kudryavtsev @ kin0shkin from https://sbtg.ru/ for the script!
'--- Begin Script
dim translateInput as string = "Rus Translate" 'Input name with Translator
dim origInput as string = "Orig Program L" 'Input name with Original audio track
dim volumeStandart as string = "100" 'Volume Orig. input when the Translator is silent
dim fadeTimeStandart as string = "1200" 'Duration increase the volume Orig. when the Translator is silent
dim volumeSpeaking as string = "60" 'Volume of the Original input when the Translator speaks
dim fadeTimeSpeaking as string = "200" 'Duration fading Orig. when the Translator speaks
dim voicethreshold as string = "0.05" 'Response threshold to the interpreter's signal, from 0 to 1 (logical scale)
'Corresponds to the values ​​(not the length) on the volume slider: 0.5 = 50% ~ = -6dB, 0.1 = 10% ~ = -20dB ...
'Response may not work with a single pulse signal, but works well with a signal such as voice or music
dim checkingIter as integer = 10 'Number of iterations to check for translator silence before firing
dim checkingIterTime as integer = 200 'Interval (milliseconds) between check iterations (recommended from 100, default 200)
'So it lasts. verifying that the translation is silent and you can turn on Orig. = checkingIter * checkingIterTime (milliseconds)
'---- End of settings ----
dim voicemeter as string = ""
dim speaking as boolean = false
dim silence as boolean = false
dim silencechecking as integer = 0
dim muted as boolean = false
do while true
dim xml as string = API.XML()
x.loadxml(xml)
voicemeter = (x.SelectSingleNode("//input[@title='"& translateInput &"']/@meterF1").Value)
if (x.SelectSingleNode("//input[@title='"& translateInput &"']/@meterF2").Value) > voicemeter
voicemeter = (x.SelectSingleNode("//input[@title='"& translateInput &"']/@meterF2").Value)
end if
muted = (x.SelectSingleNode("//input[@title='"& translateInput &"']/@muted").Value)
'API.Function("SetText",Input:="TextInput",SelectedName:="Timer.Text" ,Value:=voicemeter)
'console.writeline(voicemeter)
if voicemeter > voicethreshold And voicemeter.IndexOfAny("[E]".ToCharArray) = -1 And Not muted
if silencechecking >= checkingIter '<> 0 '!=
'console.writeline("Speaking")
silencechecking = 0
'API.Function("SetTextColour",Input:="TextInput",SelectedName:="Timer.Text",Value:="yellow")
'API.Function("SetText",Input:="TextInput",SelectedName:="Timer.Text" ,Value:="Перевод говорит! " + voicemeter)
Input.Find(origInput).Function("SetVolumeFade", volumeSpeaking + "," + fadeTimeSpeaking)
end if
'console.writeline(silencechecking)
else
if silencechecking < checkingIter
silencechecking += 1
end if
if silencechecking = checkingIter
'console.writeline("Silence")
'API.Function("SetTextColour",Input:="TextInput",SelectedName:="Timer.Text",Value:="white")
'API.Function("SetText",Input:="TextInput",SelectedName:="Timer.Text" ,Value:="Перевод молчит! " + voicemeter)
Input.Find(origInput).Function("SetVolumeFade", volumeStandart + "," + fadeTimeStandart)
silencechecking = checkingIter + 1
end if
end if
sleep(checkingIterTime)
Loop
'--- End Script
thanks 3 users thanked Stealth77 for this useful post.
jelutalica on 12/25/2021(UTC), Bob Brazner on 12/28/2021(UTC), jpetrie on 12/29/2021(UTC)
Bob Brazner
#6 Posted : Tuesday, December 28, 2021 8:42:07 AM(UTC)
Bob Brazner
Is there a way to unconditionally run this script upon loading a given preset? Or, must I start it manually with a shortcut or Stream Deck button?
#7 Posted : Tuesday, December 28, 2021 9:38:47 AM(UTC)
Assuming you started the preset manually, start it manually with a shortcut or Stream Deck (or other controller) button or open Settings -> scripting -> select script -> start
Can be potentially "dangerous" to autorun a script at preset loading , must be sure the script is completely bug free
Can always make a auto launch external option (bat file or alike) but must be sure all is fully loaded before commanding the script to run
Maybe a feature request ?
Bob Brazner
#8 Posted : Wednesday, December 29, 2021 8:41:20 AM(UTC)
Bob Brazner
I figured as much; an overt act (e.g., shortcut, button, etc.) is necessary to start scripts.
The script is great; it works perfectly and I like the settings for controlling how it behaves. The only thing I'm going to change is the variable names for the two inputs as my use case does not involve a Russian translator. This is turning out to be not as simple as it sounds. Any suggestions?
vMix-Viktor
#9 Posted : Wednesday, February 23, 2022 12:57:11 AM(UTC)
vMix-Viktor
Germany
Hey guys, thx for this amazing script :D
I unfortunately might have found an issue though:
When running the script with the "translator"-input unmuted nothing will happen until I muted and unmuted it again.
This happens every time that I start the script.
But of course, I'd like the ducking to happen as soon as the script has been started.
Any suggestions?
vMix-Viktor
#10 Posted : Wednesday, February 23, 2022 1:53:29 AM(UTC)
vMix-Viktor
Germany
Nevermind I found the mistake .D Here's the updated code:
'--- Begin Script
dim translateInput as string = "Source" 'Input name with Translator
dim origInput as string = "Duck" 'Input name with Original audio track
dim voicethreshold as string = "0.02" 'Response threshold to the interpreter's signal, from 0 to 1 (logical scale)
dim checkingIter as integer = 2 'Number of iterations to check for translator silence before firing
do while true
x.loadxml(xml)
end if
Console.WriteLine(voicemeter)
silencechecking = 0
else 'this has initially been missing so silencechecking could never reach the value of "2" unless the translator input has been silenced or turned down
end if
else
end if
end if
end if
Loop
'--- End Script
thanks 1 user thanked vMix-Viktor for this useful post.
Stealth77 on 3/13/2022(UTC)
Chris Daum
#11 Posted : Tuesday, April 19, 2022 5:28:50 AM(UTC)
Chris Daum
Germany
a while ago I posted an example.
Long time not used so no comlaining!!:-)
for example you have a moderator and then a video with sound running.
If now the moderator talks in his mic the video audio decreases
and is increased again when mod stops talking
Code:
do
Dim xml as string = API.XML()
Dim x as new system.xml.xmldocument
Dim HSLvl as string = ""
x.load("http://127.0.0.1:8088/api")
HSLvl = x.SelectSingleNode("//input[4]/@meterF1").InnerText
 ' adjust video level corresponding to mod mic level
if HSLvl >= "0.02"
api.function("SetVolumeFade", input:= 'video', value:= "50,500")
sleep(500) 'to have the audio level not jumping around...
else
api.function("SetVolumeFade", input:= 'video', value:= "100,500")
end if
'console.writeline(HSLvl) 'just for debugging and level monitoring
loop
mhngg
#12 Posted : Friday, September 8, 2023 9:23:38 PM(UTC)
mhngg
Pakistan
I was able to achieve this with one script that is available on youtube. Here is how it looks in action: https://www.linkedin.com...tm_medium=member_desktop
kirik
#13 Posted : Saturday, October 28, 2023 7:38:20 AM(UTC)
kirik
Russian Federation
Greetings! I am the same Kirill Kudryavtsev who wrote the script! Please tell me where the mistake was and what did you write instead? I have already prepared the second version of the script, it is very interesting to know about the incorrect code and its location!
thanks 1 user thanked kirik for this useful post.
Kos Live Studio on 10/24/2024(UTC)
vjmandala
#14 Posted : Tuesday, December 3, 2024 3:31:07 PM(UTC)
vjmandala
Script works a treat, thanks heaps to Kirill - only issue for me is, if I have two simultaneous vmix calls running, how does one alter script to accommodate ducking on both calls at same time?
'--- Change translateInput & origInput "names"
'--- Begin Script
dim translateInput as string = "AJAX-VMIX-CALL" 'Input name with Translator
dim origInput as string = "sMAC SRT OBS aMAC SRT OBO Vmix" 'Input name with Original audio track
do while true
x.loadxml(xml)
end if
silencechecking = 0
end if
else
end if
end if
end if
Loop
'--- End Script
nikosman88
#15 Posted : Tuesday, December 10, 2024 10:27:50 PM(UTC)
nikosman88
Greece
Was thanked: 74 time(s) in 70 post(s)
Hello. This is a very usefull script. For what you need try this version. Rename your inputs for your needs
Code:
'--- Begin Modified Script
dim translateInput as string = "Audio In 1" 'Input name for Translator
dim origInput as string = "Audio In 2" 'Input name for Original audio track
dim volumeStandart as string = "100" 'Volume of input when silent
dim fadeTimeStandart as string = "1200" 'Fade-in duration when silent
dim volumeSpeaking as string = "60" 'Volume of input when speaking
dim fadeTimeSpeaking as string = "200" 'Fade-out duration when speaking
dim voicethreshold as string = "0.02" 'Response threshold for signal detection
dim checkingIter as integer = 2 'Number of checks for silence
dim checkingIterTime as integer = 200 'Interval (milliseconds) between checks
dim voicemeter1 as string = ""
dim voicemeter2 as string = ""
dim speaking1 as boolean = false
dim speaking2 as boolean = false
dim silenceChecking1 as integer = 0
dim silenceChecking2 as integer = 0
dim muted1 as boolean = false
dim muted2 as boolean = false
do while true
    x.loadxml(xml)
    ' Get volume meter values for both inputs
    voicemeter1 = (x.SelectSingleNode("//input[@title='" & translateInput & "']/@meterF1").Value)
    if (x.SelectSingleNode("//input[@title='" & translateInput & "']/@meterF2").Value) > voicemeter1 then
        voicemeter1 = (x.SelectSingleNode("//input[@title='" & translateInput & "']/@meterF2").Value)
    end if
    voicemeter2 = (x.SelectSingleNode("//input[@title='" & origInput & "']/@meterF1").Value)
    if (x.SelectSingleNode("//input[@title='" & origInput & "']/@meterF2").Value) > voicemeter2 then
        voicemeter2 = (x.SelectSingleNode("//input[@title='" & origInput & "']/@meterF2").Value)
    end if
    ' Check if inputs are muted
    muted1 = (x.SelectSingleNode("//input[@title='" & translateInput & "']/@muted").Value)
    muted2 = (x.SelectSingleNode("//input[@title='" & origInput & "']/@muted").Value)
    ' Handle Audio In 1 (Translator) activity
    if voicemeter1 > voicethreshold and Not muted1 then
        silenceChecking1 = 0
        Input.Find(origInput).Function("SetVolumeFade", volumeSpeaking & "," & fadeTimeSpeaking)
    else
        silenceChecking1 += 1
        if silenceChecking1 >= checkingIter then
            Input.Find(origInput).Function("SetVolumeFade", volumeStandart & "," & fadeTimeStandart)
        end if
    end if
    ' Handle Audio In 2 (Original) activity
    if voicemeter2 > voicethreshold and Not muted2 then
        silenceChecking2 = 0
        Input.Find(translateInput).Function("SetVolumeFade", volumeSpeaking & "," & fadeTimeSpeaking)
    else
        silenceChecking2 += 1
        if silenceChecking2 >= checkingIter then
            Input.Find(translateInput).Function("SetVolumeFade", volumeStandart & "," & fadeTimeStandart)
        end if
    end if
    ' Wait before next check
loop
'--- End Modified Script
or this
Code:
dim translateInput1 as string = "Audio In 1" 'Πρώτη πηγή ήχου (π.χ. μεταφραστής)
dim translateInput2 as string = "Audio In 2" 'Δεύτερη πηγή ήχου (π.χ. άλλο μικρόφωνο)
dim origInput as string = "music" 'Όνομα εισόδου με το πρωτότυπο ηχητικό
dim volumeStandart as string = "100" 'Ένταση πρωτότυπου ήχου όταν τα μικρόφωνα σιωπούν
dim fadeTimeStandart as string = "1200" 'Χρόνος αυξησης έντασης όταν τα μικρόφωνα σιωπούν
dim volumeSpeaking as string = "60" 'Ένταση πρωτότυπου ήχου όταν κάποιο μικρόφωνο μιλάει
dim fadeTimeSpeaking as string = "200" 'Χρόνος μείωσης έντασης όταν κάποιο μικρόφωνο μιλάει
dim voicethreshold as string = "0.05" 'Κατώφλι αντίδρασης στο σήμα των μικροφώνων
dim checkingIter as integer = 10 'Αριθμός ελέγχων σιωπής πριν δράση
dim checkingIterTime as integer = 200 'Χρόνος ανάμεσα στους ελέγχους σιωπής
do while true
    x.loadxml(xml)
    ' Λήψη δεδομένων για την πρώτη πηγή ήχου
    voicemeter1 = (x.SelectSingleNode("//input[@title='"& translateInput1 &"']/@meterF1").Value)
    if (x.SelectSingleNode("//input[@title='"& translateInput1 &"']/@meterF2").Value) > voicemeter1 then
        voicemeter1 = (x.SelectSingleNode("//input[@title='"& translateInput1 &"']/@meterF2").Value)
    end if
    muted1 = (x.SelectSingleNode("//input[@title='"& translateInput1 &"']/@muted").Value)
    ' Λήψη δεδομένων για τη δεύτερη πηγή ήχου
    voicemeter2 = (x.SelectSingleNode("//input[@title='"& translateInput2 &"']/@meterF1").Value)
    if (x.SelectSingleNode("//input[@title='"& translateInput2 &"']/@meterF2").Value) > voicemeter2 then
        voicemeter2 = (x.SelectSingleNode("//input[@title='"& translateInput2 &"']/@meterF2").Value)
    end if
    muted2 = (x.SelectSingleNode("//input[@title='"& translateInput2 &"']/@muted").Value)
    ' Έλεγχος αν μιλάει η πρώτη πηγή
    if voicemeter1 > voicethreshold And voicemeter1.IndexOfAny("[E]".ToCharArray) = -1 And Not muted1 then
        silencechecking = 0
    ' Έλεγχος αν μιλάει η δεύτερη πηγή
    elseif voicemeter2 > voicethreshold And voicemeter2.IndexOfAny("[E]".ToCharArray) = -1 And Not muted2 then
        silencechecking = 0
    else
        ' Αν και οι δύο πηγές είναι σιωπηλές
        if silencechecking < checkingIter then
        end if
        if silencechecking = checkingIter then
        end if
    end if
loop
and with 3 mics/audios
Code:
'--- Begin Script with 3 Microphones
dim mic1 as string = "Audio In 1" ' First microphone
dim mic2 as string = "Audio In 2" ' Second microphone
dim mic3 as string = "Audio In 3" ' Third microphone
dim volumeStandart as string = "100" ' Default volume when silent
dim fadeTimeStandart as string = "1200" ' Fade-in duration
dim volumeSpeaking as string = "60" ' Volume when speaking
dim fadeTimeSpeaking as string = "200" ' Fade-out duration
dim voicethreshold as string = "0.02" ' Threshold for activity detection
dim checkingIter as integer = 2 ' Number of silence checks
dim checkingIterTime as integer = 200 ' Interval between checks
dim voicemeter3 as string = ""
dim silenceChecking3 as integer = 0
dim muted3 as boolean = false
do while true
    x.loadxml(xml)
    ' Get volume meter values for all microphones
    voicemeter1 = (x.SelectSingleNode("//input[@title='" & mic1 & "']/@meterF1").Value)
    if (x.SelectSingleNode("//input[@title='" & mic1 & "']/@meterF2").Value) > voicemeter1 then
        voicemeter1 = (x.SelectSingleNode("//input[@title='" & mic1 & "']/@meterF2").Value)
    end if
    voicemeter2 = (x.SelectSingleNode("//input[@title='" & mic2 & "']/@meterF1").Value)
    if (x.SelectSingleNode("//input[@title='" & mic2 & "']/@meterF2").Value) > voicemeter2 then
        voicemeter2 = (x.SelectSingleNode("//input[@title='" & mic2 & "']/@meterF2").Value)
    end if
    voicemeter3 = (x.SelectSingleNode("//input[@title='" & mic3 & "']/@meterF1").Value)
    if (x.SelectSingleNode("//input[@title='" & mic3 & "']/@meterF2").Value) > voicemeter3 then
        voicemeter3 = (x.SelectSingleNode("//input[@title='" & mic3 & "']/@meterF2").Value)
    end if
    ' Check if microphones are muted
    muted1 = (x.SelectSingleNode("//input[@title='" & mic1 & "']/@muted").Value)
    muted2 = (x.SelectSingleNode("//input[@title='" & mic2 & "']/@muted").Value)
    muted3 = (x.SelectSingleNode("//input[@title='" & mic3 & "']/@muted").Value)
    ' Handle Audio In 1 activity
        Input.Find(mic2).Function("SetVolumeFade", volumeSpeaking & "," & fadeTimeSpeaking)
        Input.Find(mic3).Function("SetVolumeFade", volumeSpeaking & "," & fadeTimeSpeaking)
    else
            Input.Find(mic2).Function("SetVolumeFade", volumeStandart & "," & fadeTimeStandart)
            Input.Find(mic3).Function("SetVolumeFade", volumeStandart & "," & fadeTimeStandart)
        end if
    end if
    ' Handle Audio In 2 activity
        Input.Find(mic1).Function("SetVolumeFade", volumeSpeaking & "," & fadeTimeSpeaking)
    else
            Input.Find(mic1).Function("SetVolumeFade", volumeStandart & "," & fadeTimeStandart)
        end if
    end if
    ' Handle Audio In 3 activity
    if voicemeter3 > voicethreshold and Not muted3 then
        silenceChecking3 = 0
    else
        silenceChecking3 += 1
        if silenceChecking3 >= checkingIter then
        end if
    end if
loop
'--- End Script with 3 Microphones
Be aware that im not a guru script. I gave to chatgpt the original script and ask it to do the changes. It seems to me,that it work and i was really suprised that chagpt give this script in it`s 1st attempt
