elvis55
#1 Posted : Wednesday, February 5, 2020 9:10:49 PM(UTC)
elvis55
Switzerland
Was thanked: 55 time(s) in 49 post(s)
Hallo
Larix Screencaster
Works also with public IP address. Broadcast like Larix Broadcaster. Also audio transmission.
Gruss
#2 Posted : Thursday, February 6, 2020 12:42:23 AM(UTC)
Was thanked: 921 time(s) in 760 post(s)
All is well with Larix Broadcaster and SLDP pLayer
Screencaster: vMix gets stuck of first frame received :-(
lestra
#3 Posted : Thursday, February 6, 2020 1:01:46 AM(UTC)
lestra
Saint Kitts And Nevis
Same here.
elvis55
#4 Posted : Thursday, February 6, 2020 2:06:33 AM(UTC)
elvis55
Switzerland
I don't know where the problem is. I tested all 3 apps for me over the public Internet, and all 3 work fine for me. Screencaster even with videos. The video will of course be sent as a screen. Even with audio. Audio is sent via the integrated microphone in the smartphone and the audio quality is not great on the video screen, but it is acceptable. There is no freeze in the tests I did. If I hadn't tested the apps, I wouldn't recommend them here.You may have to experiment a bit with the bit rates.
Sorry mein Englisch, Translator
lestra
#5 Posted : Thursday, February 6, 2020 6:09:58 AM(UTC)
lestra
Elvis55 you helped us a lot, I believe Screencaster is good app and it should work. Something on my end is the problem...will see...
