vMix Call
Multiple vmix calls
Hey all, new here. When I try to add a second vMix call to my production, The second call doesn't work about half the time, even from multiple different devices and settings. I don't know how to explain it but if I remove the first caller, then add the second caller it works, i can then add the first caller with a new link, its very confusing. I hope that makes sense, has anyone experienced this? I cant seem to find any information on this specific scenario.
Joined: 4/23/2017(UTC) Posts: 1,155 Location: Germany Thanks: 3 times Was thanked: 167 time(s) in 149 post(s)
vMix Pro. is that what you mean?
Ok, with PRO you have 8 calls. I thought initially you might be on HD which is just one call. I just did a show with several calls this week and no issues. The calls are based on webRTC. Apart from the license level there shouldn't an limitations on it technically. I assume your bandwidth available isn't a bottleneck.
Joined: 11/20/2020(UTC) Posts: 74 Thanks: 13 times Was thanked: 9 time(s) in 9 post(s)
possibly a network issue.
Run a speedtest, if the result is good then monitor your network.
couple of NDI streams in the network? lot of guests causing a lot of traffic? from the vMix place lot of components (switchers and all that stuff) to the internet?
many possible reasons!
vMix Call
Multiple vmix calls
