Hello Martin,
Thanks so much for your response. I am running Win 7 64 Bit on the following system:
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DALEDEW7
System Manufacturer Alienware
System Model M17x
System Type x64-based PC
Processor Intel(R) Core(TM)2 Quad CPU Q9100 @ 2.26GHz, 2268 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date Alienware A07, 03/04/2011
SMBIOS Version 2.5
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name DALEDEW7\dalede
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 8.00 GB
Total Physical Memory 8.00 GB
Available Physical Memory 4.83 GB
Total Virtual Memory 20.0 GB
Available Virtual Memory 16.2 GB
Page File Space 12.0 GB
Page File C:\pagefile.sys
The GFX card is (2) Nvidia 260M running in SLI I have the 9600 card on the mother board disabled as Microsoft has discontinued support for "hybrid" graphics configuration...
Name NVIDIA GeForce GTX 260M
PNP Device ID PCI\VEN_10DE&DEV_0618&SUBSYS_02A11028&REV_A2\4&D82FCD&0&0060
Adapter Type GeForce GTX 260M, NVIDIA compatible
Adapter Description NVIDIA GeForce GTX 260M
Adapter RAM 1.00 GB (1,073,741,824 bytes)
Installed Drivers nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver Version 8.17.12.8026
INF File oem38.inf (Section008 section)
Color Planes Not Available
Color Table Entries 4294967296
Resolution 1920 x 1200 x 59 hertz
Bits/Pixel 32
Memory Address 0xCE000000-0xCEFFFFFF
Memory Address 0xD0000000-0xDFFFFFFF
Memory Address 0xCC000000-0xCDFFFFFF
I/O Port 0x00004000-0x0000407F
IRQ Channel IRQ 19
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\nvlddmkm.sys (8.17.12.8026, 12.31 MB (12,909,672 bytes), 08/18/2013 11:02 AM)
When running Vmix Ver 9 .. Not recording and going external to Adobe Flash Media Encoder ... the Media encoder reports zero dropped frames and watching the stream (on a different computer and connection) confirms that the stream is indeed top quality.
When using Vmix ver 10 same settings, in both vmix as far as the preset goes and same settings in Adobe media encoder frames start dropping at an alarming rate and eventually the encoder crashes. (vmix still runs)
Uninstalling ver 10 and reverting to version 9 corrects the problem ... which leads me to believe there is something different in the video rendering or handoff to the media encoder between these two versions???
At the moment I am doing a webcast for a customer and will soon travel to L.A. for another however when I have a free moment I will happily make a video of whats going on if you would find that helpful... We could even schedule a time where you could watch a stream from vmix ver 9 VS vmix ver 10 if you like...
I greatly appreciate your time and interest in the matter...
Sincerely
Dale
admin wrote:Hi Dale,
What version of windows are you running, what CPU and what recording options have you selected?
Also, do the dropped frames show up in the recording or somewhere else?
