Zentech
#1 Posted: : Thursday, February 25, 2010 11:26:29 AM(UTC)
Zentech
Hello all,
Congratulations on the RC1 release...what a great tool this is! I reviewed the pricing and it seems fair.
I was noticing while using vMix on my notebook that sometimes I can get the left and right arrows on my keyboard to control the fader function but it loses focus as I mix. Would it be possible to assign the keyboard to specific functions? Handy if all the notebook has is the touchpad.
Also the audio jumps around a bit as different inputs are selected...I see that I can just take the check mark out of the Select box but a 'select none' or 'mute all' would be handy right on the main vMix for live mixing. I can mute the main soundcard volume but if I want to have a track playing from an external player I would rather mute vMix. The other thing I looked for was a 'no sound device' choice under Settings on the 'Audio' tab. I have my HD Realteck audio bus card disabled as it interferes with my firewire audio recording...this creates an error window while using 'Add New Input' > 'Video'. I resolved this by adding a USB audio card.
Hope that makes sense, William
Zentech
#2 Posted : Thursday, February 25, 2010 1:56:53 PM(UTC)
Zentech
Re: Muting Audio I did find a virtual soundcard at this address http://www.e2esoft.cn/vsc/ as an option.
#3 Posted : Friday, February 26, 2010 10:35:28 AM(UTC)
Was thanked: 4160 time(s) in 1494 post(s)
There are a couple of undocumented shortcut keys already.
Function Key
Cut 0
Fade 1
Fade 2
Fade 3
Fade 4
Fade 5
Fade 6
Change Preview Input q,w,e,r,t,y,u,i,o,p (in order as the inputs appear in vMIx, for example R would change to the 3rd one across)
Also, a mute all button is easy enough to implement, I may just enable an option in settings to mute all inputs by default then you can select what to enable as you need to.
