good afternoon. is there a complete list of commands with a description of the actions?
Joined: 7/20/2020(UTC) Posts: 15   Location: Henfield
I've got a bit of a recurring issue with UTC losing it's connection to vMix, it's on the same machine, local IP address (127.) for vMix, can't re-sync, and the other day when this happened, even after restarting everything, it still wouldn't connect, it started the day fine though.
Anyone got any ideas why this may be happening?
Cheers
Joined: 11/27/2023(UTC) Posts: 85  Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
UTC seems to a bit troublesome since it is not updated of lately...I use Panel Builder which works much better, plus it is much easier to understand and set up ... you should give Panel Builder a try. ... plus it has a GUI that is more like a real hardware switcher...been using since it was launched, and do not use UTC anymore ...
