chchchchilly
#1 Posted : Sunday, February 23, 2025 9:47:21 AM(UTC)
chchchchilly
Finished a build from scratch last night and cannot get it to post, can’t even get a display. First off, build specs (essentially the Obtanium Reference System with a GPU difference):
PROCESSOR (CPU) - Intel Xeon W5-2565X
MOTHERBOARD - Gigabyte MW83-RP0
GRAPHICS CARD (GPU) - GeForce RTX 5070 Ti
PRIMARY STORAGE (SSD) - Samsung 990 PRO 1TB M.2
SECONDARY STORAGE (SSD) - Samsung 970 Evo Plus 2TB M.2
MEMORY (RAM) - Corsair 64GB WS DDR5 5600MTs (4x 16GB sticks)
CAPTURE CARDS - 2x Blackmagic Decklink Quad 2
CPU COOLER - Silverstone XE360-4677 AIO
360mm Radiator with 3x 120mm Fans
POWER SUPPLY (PSU) - Seasonic Focus GX-1000 V4 1000W
CASE - SilverStone SST-RM44 Server Case
Things I have tried so far: swapped the 5070 Ti with an old 1050 Ti, HDMI gives me no display with either.
Removed the Decklinks in case they were causing some interference, will reseat later once I’m past installing Windows.
I tried VGA direct from the motherboard, still no dice. With and without a GPU seated.
Reduced memory modules from 4x16GB memory sticks to 2x16GB and 1x16GB stick, no difference.
Tried booting with the BIO_RCVR (BIOS Recovery) jumper in either Default and On positions, tried BIOS_PWD jumper (BIOS Password Reset) swapped as well.
I double checked that the CPU pins were good and I don't see any issues.
As far as I can tell, no bent pins on the board. So I’m just completely up against the wall at this point. Any thoughts?
Full view of build internals
CPU pins on motherboard
Kayo33
#2 Posted : Tuesday, February 25, 2025 1:18:18 AM(UTC)
Kayo33
chchchchilly
#3 Posted : Tuesday, February 25, 2025 3:46:19 AM(UTC)
chchchchilly
Originally Posted by: Kayo33 Go to Quoted Post
I was unable to find any directions on upgrading the BIOS without any sort of display. Gigabyte's manual only showed how to upgrade it by navigating into the BIOs, but I literally just have a black screen regardless of what GPU I use, discrete or integrated.
Xavi137
#4 Posted : Tuesday, February 25, 2025 11:51:37 AM(UTC)
Xavi137
Hi
Several tests...
Make sure the RAM is placed in the sockets that fit according to the manual.
Temporarily connect the graphics card to a different PCIe than the first one. On the fifth, sixth or seventh PCIe
If the above does not work, then try a minimal assembly but with the motherboard on a table with foam outside the box. Only graphics, minimal RAM and the power supply. Turn on by bridging the pins that correspond to the power on the motherboard.
If it still fails, try testing with another power supply.
DeanJohnsonProductions
#5 Posted : Thursday, March 6, 2025 10:02:29 AM(UTC)
1a. remove the capture cards
1. are the fans spinning on the 5070 ti
2. is the cpu fan spinning
3. try to boot with 1 stick of ram. with each boot attempt try another stick
4. the 5070 ti most likely has 3 Display Port outputs and 1 HDMI out. Try them all.
5. each time you do a new reboot click the power to off on the power supply to discharge the system.
6. make sure the correct power cables are being plugged into the correct spots. they may have the right number of pins but should be labeled PCIe and CPU.
7. try another power supply
What happens when you hit the power button. Are there beeps....do fans spin...is there a code of flashing lights from the motherboard
sinc747
#6 Posted : Wednesday, March 12, 2025 7:31:16 AM(UTC)
sinc747
Was thanked: 201 time(s) in 167 post(s)
Originally Posted by: DeanJohnsonProductions Go to Quoted Post
Are there beeps....
This can be the best way to find out why your system will not POST. Most systems do not come with that small internal speaker. Worth having one on hand as a troubleshooting tool.
- Tom
vstiku
#7 Posted : Tuesday, March 18, 2025 11:05:24 AM(UTC)
vstiku
Hello! I completed the build last night and am facing the same problem. Everything appears to start as normal.. but there is nothing being output on the display ports or the hdmi port. You apparently used a different GPU but I am using the same GPU as well. Were you able to resolve your issue?
Kayo33
#8 Posted : Tuesday, March 18, 2025 2:36:02 PM(UTC)
Kayo33
Do you have access to the motherboard's BIOS?
There may be a setting to adjust there.
Jonw
#9 Posted : Saturday, April 12, 2025 7:44:34 AM(UTC)
Jonw
I have the same exact build as you and had the same problem.
I was able to install windows, but once the graphics driver is installed the system would restart and then wouldn't post.
I reached out to gigabyte support, and he suggested not using windows 11 versino 24h2, but installing 23h2
Once I did that the system posted and I was able to install all the drivers.
The system does still have sometimes won't load windows, it'll hang on the boot and I have to hard reboot it until it will load. but once it's up and running it has been stable.
thanks 1 user thanked Jonw for this useful post.
sinc747 on 4/19/2025(UTC)
sinc747
#10 Posted : Saturday, April 19, 2025 4:44:37 AM(UTC)
sinc747
Originally Posted by: Jonw Go to Quoted Post
I reached out to gigabyte support, and he suggested not using windows 11 version 24h2, but installing 23h2. Once I did that the system posted and I was able to install all the drivers.
This is a very interesting discussion as I have faced many of the same issues. I was able to get Windows 11 to install, but installing the Nvidia graphics driver was a fail. A System Restore got me back to a bootable W11 but with no graphics card driver. I was finally able to update the BIOS and it was much simpler than I anticipated -- just d/l the latest BIOS (R9) and used the Flash feature in the current BIOS. Easy-peasy.
I reached out to Gigabyte Support and their first question was whether I had installed the TPM module. I'm tracking that down now.
But I'm stumped on how to install 23H2. Where can a find that? Ideas, please.
- Tom
sinc747
#11 Posted : Tuesday, April 22, 2025 7:34:26 AM(UTC)
sinc747
UPDATE
Gigabyte Tech Support followed up with me and said that a TPM module may not really be needed. He also sent me a link to the Windows 11 23H2 ISO (from his server). Had to google "how to install Windows 11 from ISO" and found that RUFUS is a reliable third party app to assist. I was able to install Windows 23H2 with no issues*. I was then able to install the Nvidia driver for the RTX 4080 Super with no issues. I also needed to install the LAN driver from the Gigabyte MS83-RP0 support website before I could get online and begin Windows Updates.
CONTINUING ISSUES
*System crashes periodically. Sometimes after a few moments of inactivity. Sometimes in the middle of a work session. A restart is necessary.
System seems sluggish in response to any mouse click or keyboard input. Is that to be expected with a workstation?
Any ideas?
- Tom
Kayo33
#12 Posted : Wednesday, April 23, 2025 1:37:19 AM(UTC)
Kayo33
With Xeon W-2500
Only 4 x DIMMs supported
Must be installed in slots P0_A0 / P0_B0 / P0_C0 / P0_D0
Capture d'ecran 2025-04-22 171742.jpg (70kb) downloaded 81 time(s).
For PCIe slots
PCIe slots 4 / 5 / 6 are not supported
Capture d'ecran 2025-04-22 171813.jpg (73kb) downloaded 81 time(s).
This card really isn't great.
The PCIe slots are 2x Gen 4.0 and 2x Gen 5.0 at x16.
Apart from the GPU, there's no point in having x16 slots for capture cards.
This reduces all CPU lanes on the PCIe slots and RAM.
No M2 SSDs benefit from this.
All other peripherals go through the chipset.
server_manual_MW83-RP0_e_v10 222_page-0001.jpg (174kb) downloaded 77 time(s).
If you can return the card, I recommend going with the ASrock W790 WS.
sinc747
#13 Posted : Wednesday, April 23, 2025 3:37:28 AM(UTC)
sinc747
Good info, thanks.
Have you used the ASRock W790 WS?
- Tom
Kayo33
#14 Posted : Thursday, April 24, 2025 6:26:38 AM(UTC)
Kayo33
No, I haven't opted for the Obtinium system yet.
But I took a look at the motherboard manuals and on the few LGA4677 motherboards that exist,
I've only seen two boards that distribute the CPU lanes to both PCIe and M2 slots.
With the limitations of the Xeon W2500 series:
Only 4 DIMMs
64 CPU lanes
I've only found two boards where the M2 use CPU lanes.
Gigabyte W790 AI TOP:
Only 3 x PCIe slots (x16/x16/x16) + 2 x M2 (x4/x4)
I don't know what they did with the last 8 CPU lanes? There must be an omission somewhere (either the last two active M2 slots or a fourth PCIe slot at x8).
W790 AI TOP PCIE SLOTS.jpg (55kb) downloaded 60 time(s).
W790 AI TOP M2 SLOTS.jpg (74kb) downloaded 62 time(s).
ASRock W790 WS :
4 x PCIe slots (x16/x8/x16/x8) + 4 x M2 (x4/x4/x4x/4)
and 1 PCIe 4.0 x4 slot managed by the W790 chipset (which allows an upgrade for a 40 Gbps network card, for example)
and which still leaves some headroom thanks to DMI 4.0 x8.
ASRock PCIE CPU LANES.jpg (27kb) downloaded 61 time(s).
ASRock M2 CPU LANES.jpg (100kb) downloaded 61 time(s).
asrock w790 ws.jpg (199kb) downloaded 29 time(s).
All other cards (Gigabyte MW83-RP0/Asus Pro WS W790) use the CPU lanes only on the PCIe slots.
Given that most capture cards are x8, and considering the price, the ASRock is cheaper
Kayo33
#15 Posted : Friday, April 25, 2025 8:00:51 AM(UTC)
Kayo33
For the Gigabyte MW83-RP0, the specifications state:
OS supported = W11 Enterprise
I think you should create a W11 Pro ISO with the integrated VGA driver.
https://www.gigabyte.com...rev-1x-3x#Support-Driver
sinc747
#16 Posted : Saturday, May 24, 2025 4:40:45 AM(UTC)
sinc747
For anyone following this thread and building an Obtanium system, here's a screenshot of a change I would suggest you make in the Gigabyte MW83-RP0 BIOS. This will greatly reduce the BOOT time.
Have a question/ Give me a shout.
- Tom
Gigabyte MW83-RP0 BIOS mod.jpg (3,711kb) downloaded 6 time(s).
