Split File Recording: Frame Drops between files
Joined: 8/22/2021(UTC) Posts: 34 ![Man Man](/Themes/yafpro/male.gif) ![Germany Germany](/Content/images/flags/DE.png) Thanks: 3 times Was thanked: 4 time(s) in 4 post(s)
Hi guys,
I still have a problem with vmix that makes it unusable if you do recordings with the split files option. This bug is still active since ever. This is what I did:
1. Setup vmix to play a simple test video file with audio and video. 2. Started recording in vmix AVI to a NVME-Disk with 1 minute chunks. 3. converted recording to MOV HQ with the vmix converter 4. put the recorded files (5 Minutes) together in Davinci Resolve
Result: There are always one or two frames missing at the end (or the beginning) of the seperate recording files. So it is completely unusable in production use because you can't put it together later.
I tried it on an old DELL 7710 Workstation Laptop with a Nvidia M3000M but also on a modern vmix device with a RTZ 3080. No difference. Also tried it with or without hardware encoding. No difference.
Anybody have an idea?
Joined: 7/23/2013(UTC) Posts: 123 ![Estonia Estonia](/Content/images/flags/EE.png) Location: North Thanks: 12 times Was thanked: 13 time(s) in 11 post(s)
Ran into the same issue with MP4 recording with 15 min splitting.
I think this is pretty unacceptable considering a master record of the production.
Joined: 1/13/2010(UTC) Posts: 5,168 ![Man Man](/Themes/yafpro/male.gif) Location: Gold Coast, Australia Was thanked: 4396 time(s) in 1543 post(s)
Unfortunately some video editors may drop some audio samples at the end of files and we have no control over that.
All I can suggest is to make sure your vMix is up to date, as there have been a couple of small fixes for this over the years, but as of the latest updates both MP4 and vMix AVI should preserve the frames and audio between splits and it is up to the video editor to correctly handle them.
To make things more challenging, the audio format used with MP4 (AAC) can't be perfectly synced up to the frame rate anyway, so its not really the video editors fault either.
That said, it is also worth pointing out that vMix AVI is a fault tolerant format, so there is not really any need to use split recording for that. So using vMix AVI is recommended and then converting that to MOV for Davinci Resolve.
I had the problem with Davinci Resolve, that is a very important editing software, so it should work, I guess.
Is there any way to open VmixAVI in Resolve? As far as I know, Resovle doesn't use any installed encoders under windows.
I've updated my initial reply with some more information. Unfortunately its not really possible for exact split timing in MP4 due to how the audio is encoded, so its not really the video editors fault either.
If you do try vMix AVI, you can convert that to MOV using the vMix Media Converter included with vMix and then avoid using the split option entirely.
Originally Posted by: admin ![Go to Quoted Post Go to Quoted Post](/Themes/yafpro/icon_latest_reply.gif) I've updated my initial reply with some more information. Unfortunately its not really possible for exact split timing in MP4 due to how the audio is encoded, so its not really the video editors fault either.
If you do try vMix AVI, you can convert that to MOV using the vMix Media Converter included with vMix and then avoid using the split option entirely. This needs to long to convert. After a show, sometimes the customer wants to have the recording in a fast time. my workaround at this time is to record with a hardware device that can do ISO recordings and also works good together with Davinci.
