JDroadie
#1 Posted : Wednesday, December 18, 2024 8:02:01 AM(UTC)
JDroadie
So when we rename zoom callers I see in the Vmix 27 changelog that in the background the Plugin continues to use actual names, this is fine except that if a caller logs in in twice, ie PC and celphone (he has reasons) Vmix/Plugin sees the same guy and gets confused when putting into a layer etc., causing the wrong video to populate. Renaming doesn't help as we see it uses the login/original names.
can there be a check box to override naming>?
Similar Topics
Triggering Zoom Names of Virtual Sets (General Discussion)
by Brian D. 10/27/2018 1:39:28 PM(UTC)
