Feature Requests
Sending Mix inputs ("Submixers") as NDI outputs
It would be very helpful if vMix could present the Mix inputs (or submixes, as I think of them) as NDI sources on our network - along with cameras /calls / audio inputs.
Joined: 4/23/2017(UTC) Posts: 1,155 Location: Germany Thanks: 3 times Was thanked: 167 time(s) in 149 post(s)
You already have two options. Tick the checkbox to add NDI per input or use the dropdown in the output settings and set it to an input and use the 4 outputs with that.
Thanks, but if Quote:Tick the checkbox to add NDI per input is refering to the Cameras / Calls / Audio Inputs CheckBox under Additional NDI Outputs, this does not give you the Mix inputs. As for the External Outputs; yes, that works - but we are limited to only four, and I have better use for these in other areas :)
Feature Requests
