RuneK
#1 Posted : Monday, April 15, 2024 11:33:24 PM(UTC)
RuneK
Norway
It would be very helpful if vMix could present the Mix inputs (or submixes, as I think of them) as NDI sources on our network - along with cameras /calls / audio inputs.
mavik
#2 Posted : Monday, April 15, 2024 11:43:54 PM(UTC)
mavik
Was thanked: 168 time(s) in 150 post(s)
You already have two options. Tick the checkbox to add NDI per input or use the dropdown in the output settings and set it to an input and use the 4 outputs with that.
RuneK
#3 Posted : Monday, April 15, 2024 11:53:31 PM(UTC)
RuneK
Norway
Thanks, but if
is refering to the Cameras / Calls / Audio Inputs CheckBox under Additional NDI Outputs, this does not give you the Mix inputs.
As for the External Outputs; yes, that works - but we are limited to only four, and I have better use for these in other areas :)
fgolman
#4 Posted : Wednesday, October 30, 2024 10:46:48 AM(UTC)
fgolman
+1
nikosman88
#5 Posted : Wednesday, October 30, 2024 9:09:51 PM(UTC)
nikosman88
Greece
Was thanked: 67 time(s) in 63 post(s)
+1
