SportsNetUSA.net
#1 Posted : Monday, March 18, 2024 12:50:01 PM(UTC)
SportsNetUSA.net
Do you have AJA Control Panel on the computer? If so, then use it to access and change settings.
However, Kona 3G cards will not be recognized by vMix. Kona 3G is no longer on the vMix Supported Hardware page.
https://www.vmix.com/software/su...are.aspx#capturehardware
I think vMix 23 or 24 were the last version to support Kona 3G cards.
SportsNetUSA.net
#2 Posted : Tuesday, March 19, 2024 1:21:29 PM(UTC)
SportsNetUSA.net
Well you use the AJA software to change to Level B BEFORE you launch vMix.
sinc747
#3 Posted : Wednesday, March 20, 2024 8:22:19 AM(UTC)
sinc747
Was thanked: 197 time(s) in 163 post(s)
Looks like SportsNetUSA.net is correct about vMix dropping supporting for the KONA 3G. You may find that you are able to use the card in some capacity with vMix, but that does not mean that vMix supports the card and all of its functions.
So it is unreasonable of you to expect vMix to work with this card as you hope.
BTW, it is viewed as an insult to call someone illiterate. I am sure you did not intend that in your post.
- Tom
Similar Topics
AJA Kona 3G Audio Breakout Box (Hardware Compatibility)
by Bruce Hamady 12/24/2020 9:44:05 AM(UTC)
AJA KONA 3G Video Capture Card (Hardware Compatibility)
by Joeboe 1/9/2019 11:47:45 AM(UTC)
AJA Kona 3g and Motherboard Question (Hardware Compatibility)
by LAJDigital 9/18/2015 10:08:40 AM(UTC)
2-AJA Kona 3G cards in Magma Expressbox 3T Expansion (Hardware Compatibility)
by epicenter800 7/5/2015 10:41:13 AM(UTC)
