#1 Posted : Monday, January 22, 2024 12:45:07 PM(UTC)
Was thanked: 4171 time(s) in 1498 post(s)
27.0.0.61
Initial release
* Fix for missing participant leaving/joining messages in Zoom
thanks 9 users thanked admin for this useful post.
QuiapoChurch on 1/22/2024(UTC), jet on 1/22/2024(UTC), STADIORADIO on 1/22/2024(UTC), sam602 on 1/23/2024(UTC), raugert on 1/24/2024(UTC), stigaard on 1/24/2024(UTC), eduardocfs on 1/28/2024(UTC), avsoundguy on 1/30/2024(UTC), orbison30 on 4/28/2024(UTC)
#2 Posted : Wednesday, January 24, 2024 1:46:31 PM(UTC)
27.0.0.62
* Fixed issue with changing vMix Call Audio Source to a bus when the buses in between are disabled (set to None).
* Fixed Zoom input going offline when the latest Zoom plugin is not installed.
thanks 5 users thanked admin for this useful post.
jet on 1/25/2024(UTC), migueldbm on 1/25/2024(UTC), eduardocfs on 1/28/2024(UTC), avsoundguy on 1/30/2024(UTC), stigaard on 4/26/2024(UTC)
#3 Posted : Thursday, January 25, 2024 8:19:11 PM(UTC)
27.0.0.63
* Fixed error on startup when language set to Korean
thanks 4 users thanked admin for this useful post.
QuiapoChurch on 1/26/2024(UTC), skyemedia on 1/28/2024(UTC), eduardocfs on 1/28/2024(UTC), avsoundguy on 1/30/2024(UTC)
#4 Posted : Sunday, January 28, 2024 7:15:57 PM(UTC)
27.0.0.64
* Fix for UWPInterop.dll crash in Desktop Capture "WindowsGraphicsCapture" when selecting some invalid windows that may appear in the list on some systems.
* Big improvements in performance when handling very large numbers of participants in Zoom meetings
vMix does this by reducing the number of notifications when a large number of participants join at once and optimising the menus and lists showing all the participants
* Fix for vMix Social settings from 26 not migrating over to 27
* Zoom meetings can now be disconnected while the connection is still in progress
* Some forms of Zoom Webinars may now work in vMix as long as the following are true:
1. The vMix participant is promoted to Panelist by the Webinar host. (vMix will show as "connecting" until the promotion occurs)
2. The Webinar operates in Zoom Meeting mode. "Events" are not supported.
Thanks to Dean from 5by5.ca for his assistance!
thanks 8 users thanked admin for this useful post.
Simsyuk on 1/28/2024(UTC), raugert on 1/29/2024(UTC), eduardocfs on 1/29/2024(UTC), Mano Bakker on 1/29/2024(UTC), Hitman007 on 1/30/2024(UTC), avsoundguy on 1/30/2024(UTC), Peter Berglund on 1/30/2024(UTC), jet on 1/31/2024(UTC)
#5 Posted : Wednesday, January 31, 2024 1:21:56 PM(UTC)
27.0.0.65
* Fix for error on new preset window when using older Basic and SD editions
* Fix for missing Zoom Meetings with no start time in the dropdown list
monamiga on 1/31/2024(UTC), jet on 1/31/2024(UTC), spinfold on 1/31/2024(UTC), avsoundguy on 2/1/2024(UTC), eduardocfs on 2/14/2024(UTC)
#6 Posted : Thursday, February 1, 2024 3:29:54 PM(UTC)
27.0.0.66
* Improved isolation to prevent a crash in Zoom SDK from crashing vMix
* Fix for Streaming Use Hardware Encoder not displaying on Windows systems with Turkish language set
* Added back Mouse Wheel for Audio Mixer faders
jet on 2/1/2024(UTC), Simsyuk on 2/2/2024(UTC), carmelo on 2/2/2024(UTC), Hitman007 on 2/2/2024(UTC), eduardocfs on 2/14/2024(UTC)
#7 Posted : Tuesday, February 6, 2024 6:15:06 PM(UTC)
27.0.0.68
* Fix for error when resetting Stream RTSP input when a reconnection is already in progress
* Fix for crash when opening AVI files in MJPG format
* Fix for SetVolumeFade not updating API XML and Activator InputVolume values
jet on 2/6/2024(UTC), QuiapoChurch on 2/6/2024(UTC), Acid on 2/7/2024(UTC), Chircanu on 2/9/2024(UTC), eduardocfs on 2/14/2024(UTC)
#8 Posted : Tuesday, February 13, 2024 1:23:53 PM(UTC)
27.0.0.69
* Fix for PFL not working for List inputs
* Fix for line flicker that can occur on corners of borders during some merges
* Meters Pre-Fader checkbox added to settings to make default for new inputs
New Zoom Plugin
A new optional update to the Zoom Plugin is available at the page below:
https://www.vmix.com/zoomplugindownload/
This fixes an issue using Streaming Capture Mode when local recording is enabled on the meeting settings.
QuiapoChurch on 2/13/2024(UTC), Simsyuk on 2/13/2024(UTC), eduardocfs on 2/14/2024(UTC), Hitman007 on 2/14/2024(UTC), raugert on 2/14/2024(UTC), jet on 2/14/2024(UTC), ask on 2/19/2024(UTC), fgolman on 2/25/2024(UTC), stigaard on 4/11/2024(UTC)
#9 Posted : Tuesday, March 26, 2024 4:26:03 PM(UTC)
27.0.0.72
* Fixed issue with loading some VST3 plugins that use duplicate names
* Fixed issue with *LayerAnimated shortcuts on Virtual Set, Photos and GT inputs
* A camera input configured as PsF will now record as progressive in MultiCorder instead of maintaining interlaceed.
* Performance improvements for Zoom to allow Webinars of up to 2000 participants.
(The right click Participant Source menu will now be limited to the first 100 participants, for all other participants the list in Zoom Manager can be used)
* Fixes for some icons and elements on high DPI displays set to 200% scaling or more.
* If Recording Setup is accidentally left open when starting recording, clicking OK may stop recording. Recording Setup window now automatically closed when starting recording to avoid this.
thanks 7 users thanked admin for this useful post.
monamiga on 3/26/2024(UTC), jet on 3/27/2024(UTC), vishwa.prakash on 3/27/2024(UTC), sam602 on 3/29/2024(UTC), stigaard on 3/30/2024(UTC), Peter Berglund on 4/3/2024(UTC), tridenator on 4/10/2024(UTC)
#10 Posted : Wednesday, April 24, 2024 4:36:45 PM(UTC)
27.0.0.75
* NEW Zoom shortcuts:
ZoomMuteSelf
ZoomUnMuteSelf
ZoomSelectParticipantByName
* NEW Zoom input Meeting Settings menu now has option to Mute/UnMute self. This controls the audio Zoom sends from vMix to other participants.
(Note Zoom updates require the latest Zoom plugin to be installed from https://www.vmix.com/zoomplugindownload/
vMix will not always prompt for Zoom plugin updates unless a bug has been fixed or a Zoom enforced security update has been applied)
* Fixed SetGammaY shortcuts not working correctly
* Fixed missing audio at the end of Replay MP4 exports
* Fixed documentation incorrectly stating SelectedValue instead of SelectedName for some shortcuts
* Fixed issue where Zoom chat was not showing up until Zoom Manager window opened
thanks 13 users thanked admin for this useful post.
richardgatarski on 4/24/2024(UTC), jet on 4/24/2024(UTC), RichDanby on 4/24/2024(UTC), raugert on 4/25/2024(UTC), Chircanu on 4/25/2024(UTC), sinc747 on 4/25/2024(UTC), Simsyuk on 4/25/2024(UTC), QuiapoChurch on 4/25/2024(UTC), WaltG12 on 4/25/2024(UTC), stigaard on 4/26/2024(UTC), spinfold on 4/27/2024(UTC), vishwa.prakash on 5/1/2024(UTC), knbPixels on 5/2/2024(UTC)
#11 Posted : Monday, May 13, 2024 4:32:54 PM(UTC)
27.0.0.76
* VLC input audio converter quality improvement
* Fix for MultiCorder setting incorrect audio bus for "Master" audio when previously recording Outputs set to a different audio buses.
* Fix for vMix sometimes not properly muting audio of Zoom call on systems with multiple audio outputs
tsioukas on 5/13/2024(UTC), jet on 5/13/2024(UTC), Simsyuk on 5/14/2024(UTC), monamiga on 5/14/2024(UTC)
Guest (4)
