Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4171 time(s) in 1498 post(s)
27.0.0.61
Initial release
* Fix for missing participant leaving/joining messages in Zoom
9 users thanked admin for this useful post.
27.0.0.62
* Fixed issue with changing vMix Call Audio Source to a bus when the buses in between are disabled (set to None). * Fixed Zoom input going offline when the latest Zoom plugin is not installed.
5 users thanked admin for this useful post.
27.0.0.63
* Fixed error on startup when language set to Korean
4 users thanked admin for this useful post.
27.0.0.64
* Fix for UWPInterop.dll crash in Desktop Capture "WindowsGraphicsCapture" when selecting some invalid windows that may appear in the list on some systems. * Big improvements in performance when handling very large numbers of participants in Zoom meetings vMix does this by reducing the number of notifications when a large number of participants join at once and optimising the menus and lists showing all the participants * Fix for vMix Social settings from 26 not migrating over to 27 * Zoom meetings can now be disconnected while the connection is still in progress * Some forms of Zoom Webinars may now work in vMix as long as the following are true: 1. The vMix participant is promoted to Panelist by the Webinar host. (vMix will show as "connecting" until the promotion occurs) 2. The Webinar operates in Zoom Meeting mode. "Events" are not supported. Thanks to Dean from 5by5.ca for his assistance!
8 users thanked admin for this useful post.
27.0.0.65
* Fix for error on new preset window when using older Basic and SD editions * Fix for missing Zoom Meetings with no start time in the dropdown list
27.0.0.66
* Improved isolation to prevent a crash in Zoom SDK from crashing vMix * Fix for Streaming Use Hardware Encoder not displaying on Windows systems with Turkish language set * Added back Mouse Wheel for Audio Mixer faders
27.0.0.68
* Fix for error when resetting Stream RTSP input when a reconnection is already in progress * Fix for crash when opening AVI files in MJPG format * Fix for SetVolumeFade not updating API XML and Activator InputVolume values
27.0.0.69* Fix for PFL not working for List inputs * Fix for line flicker that can occur on corners of borders during some merges * Meters Pre-Fader checkbox added to settings to make default for new inputs New Zoom PluginA new optional update to the Zoom Plugin is available at the page below: https://www.vmix.com/zoomplugindownload/This fixes an issue using Streaming Capture Mode when local recording is enabled on the meeting settings.
27.0.0.72
* Fixed issue with loading some VST3 plugins that use duplicate names * Fixed issue with *LayerAnimated shortcuts on Virtual Set, Photos and GT inputs * A camera input configured as PsF will now record as progressive in MultiCorder instead of maintaining interlaceed. * Performance improvements for Zoom to allow Webinars of up to 2000 participants. (The right click Participant Source menu will now be limited to the first 100 participants, for all other participants the list in Zoom Manager can be used) * Fixes for some icons and elements on high DPI displays set to 200% scaling or more. * If Recording Setup is accidentally left open when starting recording, clicking OK may stop recording. Recording Setup window now automatically closed when starting recording to avoid this.
7 users thanked admin for this useful post.
27.0.0.75* NEW Zoom shortcuts: ZoomMuteSelf ZoomUnMuteSelf ZoomSelectParticipantByName * NEW Zoom input Meeting Settings menu now has option to Mute/UnMute self. This controls the audio Zoom sends from vMix to other participants. (Note Zoom updates require the latest Zoom plugin to be installed from https://www.vmix.com/zoomplugindownload/vMix will not always prompt for Zoom plugin updates unless a bug has been fixed or a Zoom enforced security update has been applied) * Fixed SetGammaY shortcuts not working correctly * Fixed missing audio at the end of Replay MP4 exports * Fixed documentation incorrectly stating SelectedValue instead of SelectedName for some shortcuts * Fixed issue where Zoom chat was not showing up until Zoom Manager window opened
13 users thanked admin for this useful post.
richardgatarski on 4/24/2024(UTC), jet on 4/24/2024(UTC), RichDanby on 4/24/2024(UTC), raugert on 4/25/2024(UTC), Chircanu on 4/25/2024(UTC), sinc747 on 4/25/2024(UTC), Simsyuk on 4/25/2024(UTC), QuiapoChurch on 4/25/2024(UTC), WaltG12 on 4/25/2024(UTC), stigaard on 4/26/2024(UTC), spinfold on 4/27/2024(UTC), vishwa.prakash on 5/1/2024(UTC), knbPixels on 5/2/2024(UTC)
27.0.0.76
* VLC input audio converter quality improvement * Fix for MultiCorder setting incorrect audio bus for "Master" audio when previously recording Outputs set to a different audio buses. * Fix for vMix sometimes not properly muting audio of Zoom call on systems with multiple audio outputs
