arszu
#1 Posted : Wednesday, January 17, 2024 1:32:01 AM(UTC)
arszu
Poland
Asus PROART Z790-CREATOR WIFI
Intel Core i9-14900K
ARCTIC Liquid Freezer II 360
Kingston FURY 64GB (2x32GB) 5600MHz CL40 Beast Black
PNY 1TB M.2 PCIe Gen4 NVMe XLR8 CS3140
DeepCool PX1000G
PNY GeForce RTX 4080 Verto 16GB GDDR6X
Fractal Design Pop XL Silent Solid
Eelgato Cam Link Pro
BlackMagic Decklink 8K
My configuration - is it ok?
#2 Posted : Wednesday, January 17, 2024 8:38:22 PM(UTC)
Was thanked: 501 time(s) in 470 post(s)
@arszu
That MB & CPU will only support one Capture card:
https://www.asus.com/ca-...0-creator-wifi/techspec/
arszu
#3 Posted : Wednesday, January 17, 2024 9:08:09 PM(UTC)
arszu
Poland
Witch motherboard do you recommend?
#4 Posted : Thursday, January 18, 2024 8:00:53 PM(UTC)
@ arszu
To use two or more capture cards, vMix recommends the older X-Series i9 CPUs on an X299 Motherboard as per the Obsidian and Diamond Reference Systems, but you could also use current AMD Threadripper Pro CPUs.
