SRT
Srt distribution
Hi everyone, i am new to the forum. I am using vmix many years and now i want to distribute one srt to 25 clients over internet. we have fiber internet with 500mbps upload and we are planning on sending 10mbps h264 1080p25 i am not proficient with command line etc. Please if you have a solution give me as much details as you can.
Thank you very much
Joined: 12/27/2012(UTC) Posts: 5,092 Location: Belgium Thanks: 284 times Was thanked: 921 time(s) in 760 post(s)
Originally Posted by: konstantinos Hi everyone, i am new to the forum. I am using vmix many years and now i want to distribute one srt to 25 clients over internet. we have fiber internet with 500mbps upload and we are planning on sending 10mbps h264 1080p25 i am not proficient with command line etc. Please if you have a solution give me as much details as you can.
Thank you very much
Why SRT for this ?
Joined: 12/24/2021(UTC) Posts: 353 Location: athens Thanks: 113 times Was thanked: 53 time(s) in 50 post(s)
I will agree with doggy why srt for this. But if you want to do this with srt, you dont need command line. Simply you have to give to your clients the ip and port that you configured srt and from their side they need a sw that will accept the srt feed.
what do you propose? rtmp is very unstable!
Originally Posted by: konstantinos what do you propose? rtmp is very unstable! I used rtmp from this service https://www.magicstreams.services/mediacp.php in Greece and it was ok. For SRT your network is configured correctly to work from outside your local network?
rtmp suffers from data loss. i know magicstreams and i already have 3 accounts there. Srt is much better for content delivery. If you mean port forwarding then my network is configured. send and receive is ok and tested for one stream. i am trying to do 20. Meaning i want to create an srt delivery server.
If you have a better solution than srt i will gladly hear it.
i already own castr.io but they can produce only 10 dashboards with one pull each. So an other question. if i give our clients our public ip and port and i become a listener will they be able to receive the signal? all of them?
Originally Posted by: konstantinos i already own castr.io but they can produce only 10 dashboards with one pull each. So an other question. if i give our clients our public ip and port and i become a listener will they be able to receive the signal? all of them? In theory i believe yes. But practically you have to do tests to see if is stable or not
Joined: 10/25/2012(UTC) Posts: 174 Location: Barbados
Hi, I use AWS MediaConnect or Haivision. I upload 1 stream and distribute from there.
Maxi
You must create a mutipoint, so that with a single srt entry, that is, 127.0.0.1:4200, you send multiple outputs to ip 127.0.0.1:5200
SRT
Srt distribution
