#1 Posted : Thursday, June 8, 2023 4:50:42 AM(UTC)
Was thanked: 921 time(s) in 760 post(s)
Found my small external script/app back to monitor a folder to sync with a List Input !!! Happy me after been unavailable (lost forever?) since a few year here
Did some tweaking so hope it's good for now (hence 2.0 LOL)
Use
- Start the app and be sure vMix is running before use
- Choose a folder to watch/sync with
- Click "refresh Inputs"button to update the available list of List Inputs
- Select a List input from the dropdown
- Check/uncheck the "Enable Folder Watch" to activate/deactivate or resync the list Input with the folder content
Only Add or Remove files within the folder. Do not add or remove items from the vMix List Input itself! They will not sync properly! . you can but don't complain
Somtimes a video file cannot be removed from the Watched folder due to being in use by vMix (selected?)
Only add list compatible files like videos and images (an excel file wont be good for example) , there is no filetype check build in
Any bugs please report with details on how to replicate the error!
File
Folderwatch.zip (26kb) downloaded 67 time(s).
thanks 2 users thanked doggy for this useful post.
Salvatore on 6/8/2023(UTC), nikosman88 on 6/8/2023(UTC)
Miuccia
#2 Posted : Friday, June 9, 2023 12:23:44 AM(UTC)
Miuccia
Netherlands
Works really great.
Only Windows Defender gives a threat warning, classifying it as Trojan:Script/Wacatac.H!ml. Running Windows 10 LTSC 21H2. I added it to the excluded list.
#3 Posted : Friday, June 9, 2023 4:23:06 AM(UTC)
Originally Posted by: Miuccia Go to Quoted Post
+1
Works really great.
Sorry about the warning. I have o such warning nor is it detected during a scan.
found this though
Can Wacatac be a false positive?
Yes, a Wacatac alert can be a false positive, especially if you are downloading compressed files. If you get a warning from your antivirus software that a threat was detected, take all the necessary steps to ensure it is a legit threat or not. Never open files if you’re not sure whether it’s safe to do so.
