BrentCavanagh
#1 Posted : Wednesday, November 9, 2022 3:45:55 AM(UTC)
BrentCavanagh
Canada
Ever since I upgraded my M1 Mac to the new OS Ventura, when I go to launch vMix Desktop Capture 23.0.0.1 I have random crashes - usually at launch but sometimes a few minutes later. Has anyone else ran into this and/or found a way around it that worked for them? I assume because 23.0.0.1 is now a little dated that an update to the software may be required to handle the new OS but haven't been able to find any other reports here of this issue.
Here's a snippet of the crash report when it triggers:
Translated Report (Full Report Below)
Process: vMixDesktopCapture [10532]
Path: /Applications/vMixDesktopCapture.app/Contents/MacOS/vMixDesktopCapture
Identifier: com.vmix.vmixdesktopcapturendi
Version: 1.0 (1)
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-11-08 12:36:50.0635 -0500
OS Version: macOS 13.0 (22A380)
Report Version: 12
Anonymous UUID: 3342A67A-D7F2-4735-9D9D-A570928B950D
Sleep/Wake UUID: EBA50454-5967-41D3-BD13-5F15EEEA8CBC
Time Awake Since Boot: 9700 seconds
Time Since Wake: 17 seconds
System Integrity Protection: enabled
Crashed Thread: 11
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x00003eadde6e6958
Exception Codes: 0x0000000000000001, 0x00003eadde6e6958
VM Region Info: 0x3eadde6e6958 is not in any region. Bytes after previous region: 68435445705049 Bytes before following region: 36636634224296
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
commpage (reserved) 1000000000-7000000000 [384.0G] ---/--- SM=NUL ...(unallocated)
---> GAP OF 0x5f9000000000 BYTES
MALLOC_NANO 600000000000-600008000000 [128.0M] rw-/rwx SM=PRV
Application Specific Information:
abort() called
DVE
#2 Posted : Friday, March 10, 2023 6:52:09 AM(UTC)
DVE
I'm having trouble with vMix Desktop Capture on MacOS Ventura as well. I really hope they update it soon. I'll happily pay for it!
Markle01
#3 Posted : Thursday, May 23, 2024 2:52:12 AM(UTC)
Markle01
Same exact issue here. Mac mini M1, Ventura, vMix Desktop Capture randomly crashing. Any fix in the pipeline?
