Joined: 9/29/2021(UTC) Posts: 8 Location: California Thanks: 3 times
Hi Richard, Thank you so much for your instruction. I tried to follow it, but I still can not run vMix Panel Builder. Please see the attached screen shot. Please tell me where I missed the installation steps. Thank you so much for your help. Best regards, Rebecca vMix Panel Builder Prgram 64.docx (391kb) downloaded 16 time(s). vMix Panel Builder Update Peference.docx (289kb) downloaded 10 time(s). vMix Panel Update User Setting.docx (522kb) downloaded 10 time(s). vMix Panel Update Icon.docx (2,771kb) downloaded 7 time(s).
Rank:: Advanced Member
Joined: 8/5/2017(UTC) Posts: 562 Location: Manitoba Thanks: 108 times Was thanked: 310 time(s) in 177 post(s)
Hi Rebecca, It looks like you've done everything correctly. Your installation should work. I'm wondering if you may have some anti-virus software that is preventing it from being run from the Program Files folder ?? Try copying the "VMPB 4.0.44 Win64" folder to your desktop instead and create a shortcut on your desktop to see if will run from there.. You also shouldn't need to run as administrator. If you still have trouble getting it to run, you can email me at info@studio793.ca . I'll be happy to continue to help you out. regards, Richard
Joined: 8/21/2019(UTC) Posts: 67 Thanks: 7 times Was thanked: 3 time(s) in 3 post(s)
I can also no longer open the desktop application, even older versions I have kept.
iOS version works fine, but desktop application doesn't open-- no errors displayed, it just doesn't open, even in administrator mode.
Trying to troubleshoot, will post more if I find out anything.
UPDATE: Worked around this by switching to the 32 bit application. Not sure what happened, but it works, so...
Joined: 12/14/2018(UTC) Posts: 124 Location: Clermont-Ferrand Thanks: 30 times Was thanked: 8 time(s) in 7 post(s)
Hello, Same observation, only the 32-bit version works. I'm on Windows 11 Pro 64bit It's ok on Windows 10 Pro 64bits with too version 32/64bits
Originally Posted by: MickeyMJJ Hello, Same observation, only the 32-bit version works. I'm on Windows 11 Pro 64bit It's ok on Windows 10 Pro 64bits with too version 32/64bits Thanks for the report. I will look into this... Richard
UPDATE 4.0.46 (ON HOLD for a day or so - Pending small bug fixes) fixed an issue where logging not working fixed an issue when deleting newly created objects not working on Mac since ver 44 fixed an issue where selecting Hotkey field was not reporting properly fixed PTZ Zoom Stop on Button Up improved loading response time improved TBar response various other bug fixes.. Note: There has been substantial changes in the coding. Some things may have been inadvertently missed. Please report any issues to me at info@studio793.ca
Hi Richard, just downloaded and am testing....have an issue with the icons not appearing correctly.....I also found that PB loads pretty quickly, great....but it seems to be a bit sluggish....maybe my system, but my issue so far is that with the icons check attached files
PB. 4.0.44
PB. 4.0.46
PB. 4.0.46
PB. 4.0.44
UPDATE I realise what is causing this...it is a PNG issue....I disabled Opaque, and the icons looks nice, but....but, I have lost the borders..... I also notice very sluggish audio meters
UPDATE
Think I may have found the reason...it looks as though there is a locked border or outline in front of the graphics that is placed on the icon button... I tried a new PNG file that has no border, and the same thing happens.....
Hi Joeboe, Thanks for the report. I will fix this very soon. I have put the 4.0.46 on hold until I fix this bug. If any other folks have downloaded 4.0.46, Please report any issues to me at info@studio793.caThere has been substantial changes in the coding in this version. Some things may have been inadvertently missed.
It seems that the issue with the icons and not being able to revert, Undo, (Ctrl +Z) may be the only issues so far....the sluggishness seems to from my end....but the speed with which PB loads is great...., been working on some adjustments on some presets, and things seem ok so far....
UPDATE: 4.0.47 https://cli.re/vMix-Panel-Builder-4.0.47fixed Icon Buttons background color border size not correct (caused in 4.0.46) fixed Undo (ctrl-z) not working after 4.4.46 includes the following updates in 4.0.46: fixed an issue where logging not working fixed an issue when deleting newly created objects not working on Mac since ver 44 fixed an issue where selecting Hotkey field was not reporting properly fixed PTZ Zoom Stop on Button Up improved loading response time improved TBar response various other bug fixes..
1 user thanked raugert for this useful post.
I have a question....I askked this long time ago, but can not remember the answer...I changed my Icon buttons, and deleted the old ones from the folder...How can I stop the error notice from appearing when I open PB
The reason you get the "Missing Icons" window popup, is because one or more of the buttons still needs those icons. If you deleted them, you need to put them back in the UserIcon folder or edit the buttons that use those icons and resave your template.
Ok, will check on that....Thanks
UODATE: I tried editing the buttons, but the error message keeps returningI even save with a different name, but still get the same error message....I tried appending method, that did not work either...maybe you can direct me on how to edit correctly, as I may be doing something wrong, or overlooking something
Joeboe,
1. Make a copy of your template as a backup 2. Make a note of the missing Icons that appear in the error window when you load your template. 3. Open the template in Excel as a tab delimited file 4. Look for the the name of the missing Icons in column Y and column AH 5. If the name matches any of the names in the missing Icons list then Delete those cell 6. Save the excel as a tab delimited file 7. Rename the extension of the file you just saved with .vmpb or .vmpbx if you use it on a tablet
Now, when you reload your template, you should have no Missing Icons errors. You will have to add new icons to the buttons you modified in the excel as they will now be blank.
Originally Posted by: MickeyMJJ Hello, Same observation, only the 32-bit version works. I'm on Windows 11 Pro 64bit It's ok on Windows 10 Pro 64bits with too version 32/64bits For those of you who have trouble opening the app... I'm told that it might be due to out of date printer drivers in Windows 11 (even if you aren't using them anymore). I know it sounds weird but updating your current printer drivers and deleting unused drivers fixed the problem for some users. If this fixes it for you, please let me know which printer models were affected. thanks, Richard
Now, when you reload your template, you should have no Missing Icons errors. You will have to add new icons to the buttons you modified in the excel as they will now be blank. I tried this, but I still get the same thing, some Icons missing...nothing has changed Do I delete the entire row, column, or just the words....nothing seem to work for me....when I try to open the edited file, it goes to 2 items, and freezes there, and the bar does not go any further....
Can you send me your template and yourUserIcons folder. I'll try to fix it for you..
2 users thanked raugert for this useful post.
Thanks...just sent the files as a zip file
Originally Posted by: raugert Originally Posted by: MickeyMJJ Hello, Same observation, only the 32-bit version works. I'm on Windows 11 Pro 64bit It's ok on Windows 10 Pro 64bits with too version 32/64bits For those of you who have trouble opening the app... I'm told that it might be due to out of date printer drivers in Windows 11 (even if you aren't using them anymore). I know it sounds weird but updating your current printer drivers and deleting unused drivers fixed the problem for some users. If this fixes it for you, please let me know which printer models were affected. thanks, Richard Hello, Thank you for your reply. I installed Windows 11 without an update, and I haven't reinstalled my printer yet, so no driver risk.
