mksi
#1 Posted : Thursday, June 25, 2015 11:48:48 AM(UTC)
mksi
Hi all,
I was just wondering if one can add an image ref within the HD Ticker XAML file?!
I managed to change the colour of the background etc. But was wondering if anyone had been successfull in actually adding a 'background image,' if so, what size this was labeled at etc.
Grateful for any tips.
mksi
#2 Posted : Thursday, June 25, 2015 1:26:31 PM(UTC)
mksi
UPDATE: I used the 'blank ticker' and simply photoshoped the background I wanted and then added this as an image input. (It's not ideal, but it works) STILL - I'm hoping there might be another way of doing it, so if anyone has any ideas, please get involved.
Cheers
elshorbagy
#3 Posted : Friday, June 26, 2015 8:35:03 AM(UTC)
elshorbagy
If you are not familiar with Microsoft Expression Blend, just open the animated ticker xaml file in a notepad. under the <grid> tag paste this line
<Image HorizontalAlignment="Left" Margin="0,0,0,0" Name="BackgroundImage" Stretch="Fill" VerticalAlignment="Top" Width="1920" Height="1080" Source="NewsHD5.xaml.png" Opacity="0.9" /> which I already copied from NewsHD5.xaml file.
Change NewsHD5.xaml.png with your image.
I hope that works :)
mksi
#4 Posted : Tuesday, June 30, 2015 9:20:06 AM(UTC)
mksi
Hi elshorbagy,
Thanks for that. Will give it a go and update you.
Cheers,
Mksi
User is suspended until 5/19/2029 2:05:28 PM(UTC) Winops
#5 Posted : Saturday, August 13, 2022 2:21:51 PM(UTC)
Winops
Argentina
Originally Posted by: mksi Go to Quoted Post
Hi elshorbagy,
Cheers,
Mksi
Hi mksi
is the any way to create an RTL Ticker Image in vmix ?
#6 Posted : Wednesday, August 24, 2022 9:04:26 PM(UTC)
Winops
Argentina
آHi Bro is this works for RTL ticker images ?
