GT
Align right + Bounding impossible with Text?
Joined: 11/25/2019(UTC) Posts: 42 Location: Bordeaux Was thanked: 2 time(s) in 2 post(s)
Hello, I have a little problem with Align Right and Bounding, I'd like to put some text on the right side, but if I want a background with it behind, it is simply impossible because the X Location is counted on the left side, not on the right side. That makes the title go out of the screen instead of aligning on the right side... Here's a showcase of what I mean: Does anyone know how to make this work?
Joined: 12/27/2012(UTC) Posts: 5,084 Location: Belgium Thanks: 284 times Was thanked: 920 time(s) in 759 post(s)
Originally Posted by: doggy https://forums.vmix.com/search?search=bounding+gt Whoops... Well, I mean since it's been 3 months for some people I guess a heads up is still better 😂
Joined: 3/13/2019(UTC) Posts: 7 Location: Dubai Was thanked: 1 time(s) in 1 post(s)
This clearly does not work, unfortunately - the text box seems to anchored to the left in such a case.
Joined: 6/24/2022(UTC) Posts: 3 Location: Québec Was thanked: 3 time(s) in 2 post(s)
For right aligned text and bounding, in GT you have to build your right aligned textblocks with Horizontal texture flip in Effects and when adding the input in vMix you check Mirror in the General tab.
It will be a bit weird in GT, but once flipped in vMix, you won't see the trick behind, just the result you wanted.
*I have nothing for center aligned text!
1 user thanked Simon5 for this useful post.
Joined: 9/9/2020(UTC) Posts: 6 Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hey all, Still no solution for this? I really need this to work on my layouts. What Simon5 suggested could work on layouts that doesn't contain any other text, but mine contains multiple layers (aligned left) and some aligned right that need to bound on the background...
GT
