wandinho
#1 Posted : Thursday, July 3, 2025 1:59:08 AM(UTC)
wandinho
Brazil
Hi vMix team,
Hi vMix team,
I'm currently using vMix 28.0.0.42 (64-bit) on a Windows 10 Pro system (Intel i7-11800H, 32GB RAM, RTX 3070).
I work in live hybrid events and frequently use vMix Zoom for remote contributors.
To clarify: in some events I host Zoom meetings with up to 100 participants. However, I only bring in **3 active video inputs** into vMix at any time — usually the host and two guests.
The remaining participants stay inside the Zoom call but are not added as separate vMix inputs.
That said, the system still has to handle the full Zoom room in the background, which adds to the GPU and CPU load.
To optimize performance, I'd like to **disable the Input Display (preview thumbnail)** individually — just for the Zoom inputs — and keep the preview active for cameras and titles.
I’ve seen references online about version `28.0.0.81` allowing users to right-click an input and turn off the display, but I couldn’t find this version or that feature in my current build.
Is this functionality available in any current public build?
If not, could it be considered for an upcoming release?
This would really help with performance in large Zoom-based productions, without needing to disable previews globally in the Performance settings.
Thanks in advance!
Wanderson Borges
