Systems
Obtainium benchmark improvements. Upgrade from the w5-2565X to the w7-2575X CPU and other upgrades.
The RTX Blackwell Pro has arrived
Regarding the Gigabyte MW83-RP0 motherboard from the Top Recommended Reference.
I've re-reviewed the specifications of this motherboard, and it's not at all recommended for vMix. Main points:
- Very poor heat dissipation from the motherboard's VRMs.
- The two M.2 drives depend on the motherboard's chipset. Therefore, there may be higher latency and bus saturation due to shared bandwidth.
These two reasons are very important to directly rule out this motherboard.
Joined: 10/20/2023(UTC) Posts: 102  Thanks: 2 times Was thanked: 11 time(s) in 9 post(s)
Xeon W2500 series= 64 CPU lanes Only 4 DIMMs w5-2565x.png (89kb) downloaded 96 time(s).Gigabyte W790 AI TOP:
Only 3 x PCIe slots (x16/x16/x16) + 4 x M2 (x4/x4/x4/x4) W790 AI TOP PCIE SLOTS.jpg (55kb) downloaded 100 time(s). W790 AI TOP M2 SLOTS.jpg (74kb) downloaded 102 time(s). mb_manual_w790-ai-top_102_e_page-0001.jpg (186kb) downloaded 102 time(s).ASRock W790 WS :
4 x PCIe slots (x16/x8/x16/x8) + 4 x M2 (x4/x4/x4x/4) ASRock PCIE CPU LANES.jpg (27kb) downloaded 101 time(s). ASRock M2 CPU LANES.jpg (100kb) downloaded 101 time(s). asrock w790 ws.jpg (199kb) downloaded 69 time(s).Gigabyte MW83-RP0 and Asus Pro WS W790 use the CPU lanes only on the PCIe slots.
Given that most capture cards are x8, the ASRock is best
Systems
