I would like to see a vmixcall.ninja edition. I dont mind if it will be called vmixcall.miyagi or vmixcall.cobrakai but it would be awesome to have all the WEBRTC/WHIP "magic" behind
In the yesterday vmix fun time live show, vmix team said some things about Vmix 29 new features Hope that we will also see total duration list in the API and better/easier re-arragement items inside the list inputs
Originally Posted by: Gary2theO  2 Things I would love to see.
1)Effects being recorded in replay. Would like to use LUTs in vMix but currently cannot because they do not transfer over to replay when being recorded 2)Shortcuts to turn triggers on/off. We currently used different triggers on different days and wouldn't mind to ability to script turning triggers on/off THIS (1)!! Plus mor Ountputs and or more Overlays
And vmix 29 preview release is out. Things i like 1.8 overlays yes finally more overlays 2.OMT protocol seems to be a good alternative to NDI and i hope to bre more stable in 1gbps network than NDI 3.More audio buses combinations 4.List input search item 5.oncountdown time triggers 6.Vmix Go
Things i would like to see 1.List input total duration in the API 2.SRT "connected" when a source actually have signal or not 3.Triggers like "on black or no signal" 4.Mix inputs over OMT or NDI Thank you for the great work
1) It would be good if in the Slideshow settings of a PowerPoint presentation the outline of the active slide could be made much thicker and maybe in red, or if there were an option to adjust this parameter in the Slideshow settings next to Transition Effect and Duration  slide.png (113kb) downloaded 27 time(s).2)When connecting or disconnecting in Zoom, a notification pops up in the center through the Zoom input. Why isn’t this available with vMix Call? It would be very convenient.
