Joined: 1/23/2022(UTC) Posts: 89 Location: Milton Keynes Thanks: 13 times Was thanked: 4 time(s) in 4 post(s)
From the latest beta announcement...
* New shortcuts: SetLayerAnimated, SwapLayerAnimated: These will change a layer, animating the change if possible.
Does this mean we can add or swap inputs on a layer and have it animated rather than just cut? Which animation is used and what's the transition time, or is this sent with the command? What does "if possible" mean in this context?
Joined: 12/27/2012(UTC) Posts: 5,214 Location: Belgium Thanks: 290 times Was thanked: 952 time(s) in 787 post(s)
Screenshot 2023-12-13 220517.jpg (10kb) downloaded 2 time(s). Screenshot 2023-12-13 220445.jpg (11kb) downloaded 2 time(s).animation is a move to position like a merge would do best way to get the feel of it is to try it ;-)
