Beta Discussion
Virtual Background problem
Joined: 11/30/2023(UTC) Posts: 2 Was thanked: 1 time(s) in 1 post(s)
My Output to Zoom is background blured , I have uninstalled and reinstalled the plugin , but doesn't change anything. When I installed the plugin for the very first time , in my zoom configuration , the blur background was activated, maybe the plugin took this setting and has stored it in a config file.
Thank you very much.
I've solved it uninstalling the plugin ,deleting the ZoomSDK folder in Appdata\Roaming folder and reinstalling again.
1 user thanked Juanra.Myoffice for this useful post.
Joined: 2/14/2024(UTC) Posts: 9 Location: Liverpool Thanks: 1 times
I ran into the same issue. Thanks for the post for help.
Is it possible to block this setting from being enabled when installing the plugin? I don't think a blurred background on the vMix return feed would be necessary. Or could it be an option in Zoom Manager if someone absolutely needs it?
Beta Discussion
