Beta Discussion
How to set layer mods dynamically? [Added]
Thanks: 9 times Was thanked: 44 time(s) in 37 post(s)
I am configuring dials on a Stream Deck + to tweak layers on the Active Input.
Currently there are shortcuts dedicated for each layer (e.g. to set crop for layer 1)
I want to use dial stacks to control things like layer cropping, position, size, visibility, etc.
Is there a way, perhaps with scripting or dynamic scripting to construct something like.
SetLayer + DynamicValue3 + CropX1
That way I can use another button to define the dynamic value for the layer number That would be more useful to me than having complete sets of functions for each layer.
Another approach would be If there was a new shortcut for each setLayer function… sort of like SetLayerDynamicCropX1 where defining the layer would also ask for a value of the layer number…. That would avoid the scripting and make it available to HD users instead of just Pro and above.
Your thoughts are appreciated
In the latest build…
Added SetLayerDynamic* shortcuts which will use Layer number from DynamicValue1
Looking forward to testing it out
Beta Discussion
