Beta Discussion
Demo: 'zoom around' in an input by utilizing the new shortcuts
Joined: 4/3/2022(UTC) Posts: 18 Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
Hey folks, I built a little demo for how to "zoom around" an input by utilizing the new vMix shortcuts via BitFocus Companion. This was technically doable before, but required you to build one input per desired 'zoom looks'. Example here (I merged from source -> zoom look 1 -> zoom look 2 -> back to source). In my example I am demo-ing here, you can scale to infinite desired 'zoom looks' for the price of 2 inputs in a mix. Simple breakdown of what I am doing: - making 2 copies of the input I want to add zoom movements to, and putting those 2 copies into a mix - accessing the current preview in that mix, using the new vMix 27 shortcuts to adjust its zoom/pan values, and then merging it into the output of that mix
vMix 27 zoom mix example v2.zip (2,275kb) downloaded 5 time(s).For anyone who wants to try this out themselves/edit it/adapt it for their own needs, I've attached: - a vMix bundle nearly identical to what is seen in the .gif - a Companion config for this page of buttons The two should just load up and work together, but please don't hesitate to ask me questions if needed. You will need to be on a vMix 27 preview build, and the accompanying config is for Companion 3.0.0+
I have improved the example & configuration to support an adjustable (and selectable) zoom level (150%, 200%, 250%, etc.). I also updated the vMix bundle to use a 16:9 image for simplicity's sake. Download: Adjustable Level Zoom Grid Example.zip (770kb) downloaded 1 time(s).
Added a couple more features/improvements: - tallies for current position & zoom level - ability to hot-change the zoom level (including a toggle to enable/disable this behavior) Note: the position buttons cannot be moved to other locations on their page (as their positions are referenced in order to enable the hot-change functionality) Download for vMix project bundle and Companion config: Zoom-in buttons with tallies and hot changes.zip (769kb) downloaded 4 time(s).
Beta Discussion
