Beta Discussion
ISO audio changed to MIX audio support from Zoom? [RESOLVED]
Joined: 11/21/2017(UTC) Posts: 123 Location: Philadephia, PA Thanks: 31 times Was thanked: 13 time(s) in 8 post(s)
>Added support for the audio "Mix" from Zoom instead of isolated audio feeds per participant.<
Awwww...I was really looking forward to using the ISO audio from Zoom. This feature is only currently accessible from Zoom ISO itself. I agree with the need for for mix audio too, so perhaps you could add a "mix" input from Zoom (audio only) or perhaps combine it with active speaker video support.
Please, Martin, don't take the Zoom ISO audio away! Please?
Joined: 1/13/2010(UTC) Posts: 5,162 Location: Gold Coast, Australia Was thanked: 4171 time(s) in 1498 post(s)
It's probably a good idea to try the latest vMix update before posting. If you did you would see it is a toggle option between them.
The "instead of" in the feature wording is meant that you can choose this option instead of ISO if you want to. But I have updated that line to prevent any further confusion.
But please, actually try the updates before posting here...
Beta Discussion
