Issue With Zoom - Help Me Please
Joined: 7/25/2022(UTC) Posts: 2  Location: California
Hello people,
I am trying to send vMix to Zoom and having problems with the audio. I need to send a master mix which contains the studio microphone and music which is sent to vMix through a music mixing programme called Mixxx. I only seem able to get one channel of audio at a time through to Zoom. I have read the instructions and downloaded the virtual cable.
In Zoom when I press "CABLE Output (VB-Audio Virtual Cable) I can hear just the music (although it's not very clear and sometimes cuts out) when I press "Analogue 1+2 Focusrite USB Audio) I can hear just the studio microphone clearly but no music. It's the same for a few other mic options - none of them play microphone & music together! :(
Can anyone help me? Thanks
Joined: 5/13/2014(UTC) Posts: 481   Location: Manchester, UK Thanks: 2 times Was thanked: 175 time(s) in 124 post(s)
You need to create the mix that you want to send (mic + music) in vMix by sending those inputs to an otherwise unused audio bus (eg C, D, E, etc). Then configure the vMix audio output devices to send that bus output to the VB-Audio Virtual Cable so that when you select it in Zoom it will carry the mix that you want to hear.
