rashid
#1 Posted : Monday, July 25, 2022 2:43:14 PM(UTC)
rashid
Hello All, I have an issue that I can't seem to find a solution for. When I run a speed test with nothing running I have results of (30/30 up/down), simply launching a new (or any) vMix session my network speed goes down to basically nothing. less than 1mbps in some cases. If I simply close vMix the speed instantly is returned to normal.
I have tried uninstalling vMix and reinstalling, but the same result. Has anyone seen anything like this before?
Laptop Info
Lenovo Legion Y740
i7 9750H
GTX 1060ti
16Gb Ram
1TB m.2 SSD (OS)
1TB m.2 (Media Storage)
Javeer
#2 Posted : Tuesday, July 26, 2022 1:12:51 AM(UTC)
Javeer
That is odd. I've not come across a issue like that myself. Check your task manager and see what other process open when you launch vMix.
Also, are you opening a blank vmix or a preset with inputs? if it's the preset then check the inputs that are internet dependant.
