NDI
NDI Newbie Question
If I run NDI from one program on my PC to another, am I using any network bandwidth? Will this cause any unforeseen issues? I have run several recordings from Teams NDI Broadcast to Livemind NDI recorder recently without issue but I am now planning to run a stream using Livestream Studio and Zoom. We will be sending the program feed out of Livestream Studio back to Zoom via NDI tools. It is working and the CPU load is hovering around 40% while streaming. https://nox.tips/ https://xender.vip/
Joined: 5/13/2014(UTC) Posts: 472   Location: Manchester, UK Thanks: 2 times Was thanked: 172 time(s) in 121 post(s)
Originally Posted by: haxelfebl  If I run NDI from one program on my PC to another, am I using any network bandwidth? Yes, the video data needs to travel through the network. As to how much bandwidth is being used, you could monitor one end of the connection (eg with the Performance tab of Task Manager) and see what difference it makes when you add and remove the NDI connection.
NDI
NDI Newbie Question
