raugert
#1 Posted : Thursday, April 4, 2019 1:08:13 PM(UTC)
raugert
Canada
Was thanked: 174 time(s) in 99 post(s)
vMix has a very powerful Scripting feature, but some folks are not so comfortable with coding, and may not be using scripts to their potential. So.. I made a little app that is simple to use and that will build the script for you.
Features:
- Simple to use with pulldown menus that reflect your inputs when connected to vMix.
- Build scripts offline by manually inserting the pertinent vMix info into the pulldown fields (such as: Input Name or number, Selected Name, Index, etc) . This can be useful if you often use the same input names for different vMix presets.
- Import scripts and modify them to suit your needs
- Export (save) the scripts for use in vMix or other 3rd party programs
- Quickly test your scripts as you go ! (It's not necessary to save and import them into vMix to test them). Just press "Test Script" button
If you have never written a script, I would encourage you to read the "Shortcut Function Reference' chapter in the vMix User guide to understand how to use the commands.
Screen Shot 2020-02-26 at 12.18.55 AM.png (108kb) downloaded 12 time(s).
Here's the link for those who wish to give it a try:
https://cli.re/vMix-Script-Builder-1.0.6
cheers,
Richard
thanks 22 users thanked raugert for this useful post.
ThommiTechnik on 4/4/2019(UTC), stevespaw on 4/5/2019(UTC), pba on 4/5/2019(UTC), Video Dave on 4/5/2019(UTC), AVStream on 4/9/2019(UTC), it-rttv on 4/9/2019(UTC), islyakh on 4/9/2019(UTC), echobb on 4/17/2019(UTC), kevev on 4/17/2019(UTC), QuiapoChurch on 4/21/2019(UTC), Teye on 4/27/2019(UTC), avsoundguy on 4/30/2019(UTC), Jurgen on 12/18/2019(UTC), studiodelta on 2/3/2020(UTC), Peter1000 on 2/21/2020(UTC), tkachuk.alex on 2/24/2020(UTC), clafarge on 3/25/2020(UTC), sinc747 on 3/25/2020(UTC), KnightHeart on 4/23/2020(UTC), SimpleAOB on 5/3/2020(UTC), seb666 on 6/29/2020(UTC), billh2020 on 8/27/2020(UTC)
raugert
#2 Posted : Friday, February 21, 2020 2:26:10 AM(UTC)
raugert
Canada
Updated version 1.0.4 (link in first post)
- added Mix feature from vMix23
- changed Input data to reflect "Input Name" rather than GUID. Can now be used on vMIx presets that use common names.
Richard
tkachuk.alex
#3 Posted : Monday, February 24, 2020 11:13:31 PM(UTC)
tkachuk.alex
Ukraine
Super app. THX. But could you add Cyrillic support. Names and data now are "???????"
TNX once more
Peter1000
#4 Posted : Tuesday, February 25, 2020 5:59:59 AM(UTC)
Peter1000
Switzerland
Was thanked: 37 time(s) in 28 post(s)
Cool Tool, it would be nice, if we could copy the compiled script text to the clipboard.
Thanks for your effort.
Peter
raugert
#5 Posted : Wednesday, February 26, 2020 5:14:19 PM(UTC)
raugert
Canada
Update v1.0.6 (link in first post)
- added french and cyrillic support
- choose vMix Scripts for use in vMix scripting settings or
- choose URLEncoded Scripts for use in browsers or 3rd party apps
- "import" button will import vMix scripts that were created in vMix scripting
- "save" button will save vMix scripts for importing directly into vMix scripting
- fixed incremental += in value field not always working correctly
- "new command” line now appears when clearing script
- added copy to clipboard feature
Richard
thanks 1 user thanked raugert for this useful post.
JAIRODJ
#6 Posted : Thursday, February 27, 2020 6:21:20 AM(UTC)
JAIRODJ
Was thanked: 13 time(s) in 9 post(s)
Hi
I would like to check if possible, use the command
"waiting for completed"
This command is in an example in the vmix forum, but I can't make it work.
What I want is that when you finish playing the video the following script command is executed.
Function = Fade & Input = Alex Ubago - Look at us.mp4
waitingForCompleted
Function = Fade & Duration = 100 & Input = NDI AIR2 (vMix - Output 1)
I've tried many ways but I can't do it with the script.
Can you help me please.
raugert
#7 Posted : Thursday, February 27, 2020 7:52:39 AM(UTC)
raugert
Canada
Use this Script Builder app to create the script for you . Then copy to clipboard and paste it in vMix scripting.
It should look something like this:
Function=Fade&Input=Alex Ubago - Look at us.mp4
Function=WaitForCompletion&Input=Alex Ubago - Look at us.mp4
Function=Fade&Duration=100&Input=NDI AIR2 (vMix - Output 1)
regards,
Richard
Joeboe
#8 Posted : Tuesday, August 11, 2020 9:48:49 PM(UTC)
Joeboe
Hi, I am trying to make a scoreboard for the game of cricket...I have all the batsmen scores advancing correctly, but I can not get the individual scores to total....can anyone point me in the right direction....in other words, if each batsman make 25 runs, and there are 4 batsmen, each time a batsman make a run, and I add that to his score, I want to see it reflected in the total for that team...( batsman 1= 20 runs, batsman 2= 24 runs: Total =44....)... I am not a script writer, so I need an example to work with....any help will be surely welcomed.....
Thanks in advance
