LindaPeterson
#1 Posted : Friday, January 11, 2019 1:40:44 AM(UTC)
LindaPeterson
Azerbaijan
I have two group of sports medicine facilities here in the USA that are wanting to show a video clip then transition to TV for a set amount of time then play another video clip. This will loop throughout the day. Can vMix do this?
mjgraves
#2 Posted : Friday, January 11, 2019 2:28:21 AM(UTC)
mjgraves
Was thanked: 179 time(s) in 156 post(s)
Yes, vMix could do this.
You'd need a suitable host, and a tuner, or other mechanism by which to receive the "TV" signal.
If your source is a cable TV box that might be an HDMI capture card. You could receive the TV stream via a web page(similar to YouTube) directly into vMix.
That said, you might be better off seeking a solution based upon some digital signage software. That could be less hardware intensive and easier to remote manage.
#3 Posted : Friday, January 11, 2019 2:31:24 AM(UTC)
Was thanked: 369 time(s) in 351 post(s)
@ LindaPeterson
As mjgraves sais, if you can capture the TV signal into vMix, then it is just a matter of using and configuring the PlayList feature in vMix on a loop.
Similar Topics
Automation for doctors office? Need to pick your brains.. (General Discussion)
by PrepSpin 9/23/2017 2:24:36 PM(UTC)
